Just watched a YouTube from 'sik rides' on his K10 Chevy
He has fitted headlights to the stock grill, is he a member here? Maybe he will chime in with his headlight mod?
http://https://m.youtube.com/watch?v=xAGmd5Sca7s
Checking it, thanks. "thumbsup"
The Chevy looks great but shouldn't the thread be renamed "Natedog's Ascender Fleet" at this point? :lmao:
The Bronco uses shorter bumper mounts than the Blazer but I think they are only available with the Bronco body. The GCM bumper mounts are pretty short and much stronger, they only extend about 10 mm past the end of the frame rails.
Thanks, lol. :lmao:"thumbsup"
Good info, but Horizon should sell the bumper mounts separately. GCM bumper mounts are nice, but I'm very hard on my trucks and prefer plastic since metal tends to transfer the impact to the rest of the truck instead of flexing and absorbing it. GCM aluminum bumper mounts are sweet for super scale metal bumpers, but I wish they had a nylon option, I'd buy that. "thumbsup"
EDIT: The front bumper sticks way out and needs shorter front bumper mounts. I'm cutting them shorter, but there may not be enough plastic left for the screws to hold the bumper securely. It looks like the Ascender Bronco mounts would work, but Horizon's site gives no dimensions to know for sure. Horizon lists VTR23046 bumper set as fitting all Ascenders, Blazer (kit and RTR), K10 and Bronco. I found that the Bronco front bumper mounts are listed as part number VTR23046, but don't find any mention of this part on the internet.
Bronco exploded view here, you can see the parts and part numbers:
http://www.horizonhobby.com/pdf/VTR03031-Exploded_View.pdf
While setting up rear links and working on swaybar mount, it appears that my first Blazer RTR rear upper link mount is more upright and therefore the same length rear upper links don't result in the same amount of pinion angle. I added a couple spacers to tilt the rear pinion up slightly and it was not enough, so started measuring everything thinking I used wrong links or something. After a bunch of measuring and some disassembly, I found that my newer RTR and kit both have the same length rear upper link mount, but that it is angled back more and rests right up against the top of the rear axle housing. My first RTR it's more upright, going to have to see how this affects TT.
