M J
Have an Axial front sway bar kit coming my way - thanks for the info! How cold was it in those pictures? I bet it warmed up quickly once the sun came up(does that out here).
That K10 is looking awsome mate! Im loving that yellow too, just different enough from the RTR yellow.
Sliders look great, and way to think outside the box with this mod. Sorry I didn't get to your SS ones, Maybe we can talk about them when we see you on our trip!!"thumbsup"
Ernie
Awesome idea on the bumpers. I'm for sure going to do it to my new truck since I've tucked and cut the body up already.
Ben
Rockhugger bumper mod looks awesome on both rigs!!!
I like that you brought them in closer to the chassis a bit as well... The unstoppable just got... Pause... More unstoppable!!!
Thanks, looks that way, but it clears. My rims are not spaced out at all, but I have looked at drilling and tapping some Traxxas 2wd Slash front aluminum hexes if it needs more clearance later.
Hitec HS-7950TH fitted with Axial clamping horn, steering draglink to top right steering knuckle, clears everything and is almost zero bumpsteer! Few different picture angles to show everything going on. This is all mocked up and working, but will probably change some Looking at Lunsford approximately 4x132mm titanium link tie-rod with standard Vaterra Ascender ball ends at both ends, giving max ground clearance and strength. Draglink is currently leftover Axial AX-10 kit rod (will measure and post later) with Traxxas ball ends, but will prolly also go with Lunsford ti turnbuckle for fine adjustable tuning. Servo mounts are going to flip and servo on top (to lower servo slightly), then install Hudy high clearance slightly longer horn for better steering throw and tiny lower CG. 8) "thumbsup"
Sitting on the tires at ride height.
Suspension completely un-weighted with tires off the ground.
Full compression, nothing hits anywhere, servo horn clears frame rail etc.!
Very nice write up Nate, you always have those wheels turning in your head!"thumbsup"
Ernie
Hi nate!
This looks very good "thumbsup"![]()
