Thanks for sharing that. Awesome expansionThis video explains really well what happens. Although this is a full size vehicle, the basics are the same.
Basically the yokes on your drives shafts should be inline and at the same angle as each other.
https://www.youtube.com/watch?v=gmV4qwLfOMY
Loaded up the Nashbar SS 29er and moved to a better crawl spot! Radio stayed put all the way out on dirt fire roads and single track...even the rocky rooty spots didn't shake it loose. Then the return trip mostly on paved path was no problem at all.
Put some flat pedals back on, I wanted to hike around easily while crawling, not with carbon soled bike shoes lol.
Ascender fastened to Camelbak with velcro straps (like battery strap, but longer and wider). I used 8" length Black Hook and Loop (Frys.com #3358942, Manufacturer: THE, UPC #050286806056, Model #20-8-0), but Fry's Electronics has them in 6" and 12" too. It took three of the 8" put together to hold transmitter to the stem and bars.
FRYS.com | THE
It was dusk and the nearly full moon was rising early
Star of Bethlehem?
“Star Of Bethlehem†Visible on June 30th for the First Time in 2,000 Years. | elephant journal
Need to get headlights and rocklights, I was wearing small LED headlamp for light
The moon
Not a bad deal at all.
Looking good nate i like my risers
LIFE IS GOOD
Is this by the American River bike trail? I used to live right by there. MTB and RC cars....My two favorite things!!!!"thumbsup"
Hey Nate, I had to pull the axial sway bar off as it was really killing the articulation of the rear end. I was curious if you ran into that and if you did, how you worked around it. I ended up getting longer screws to further outboard the shocks and it's seemed to help somewhat. I'm wondering if I am using the stiffest sway bar (never got my micrometer out to check).
I recently dealt with this issue myself. I few weeks back, I had a day where my Ascender just started acting like it was made of Velcro. It was an amazing day of crawling where I was able to hit a lot of lines that I was not able to before. In my next maintenance session, I noticed that the wraith swaybar had broken right at that thin spot in the middle. I have been crawling without it since and have seen a noticeable improvement in crawlability without a swaybar in the mix. My Ascender is over a year old now, well broken in, and still using the stock kit shocks.
I have seen this myself.....my nephew has a stock unit.he has made a couple sections at our local spot that I have an issue with....with that being said,when it comes to almost vertical climbs,his will lift the front tire and flip over.mine will make those climbs.its all personal preferance.
Need to put some lights on that Ascender so you don't have to shine a flashlight at it while driving at night.
Just a question as i'm yet to put my hands on an ascender, has anyone tried twin hammers swaybars? or are they incompatible due to measures?
Hey Nate I'm using the 2wd sct set,for kennys truck I did just a quick setup cause he may want them off.I'll post up some pics in a but.Racer,
Just looked them up, how wjde are they from end to end? The diameters look much better (thinner) for controlling TT while getting good flex. I see there are kits for the 22-4 and 22SCT, which are you using? Looking forward to your results and input.
Kit for Losi 22-4:
Sway Bar Kit, Front & Rear: 22-4 (TLR334006): Team Losi Racing
Kit for Losi 22 SCT:
Sway Bar Kit, Rear: 22SCT (TLR334002): Team Losi Racing
Cool - I remember the piano wire you mentioned previously. I'll see if I can come up with something.
Here's some pics of this setup,like I said just a quick pop on.he way not like it.losi goes by color code for sizing.
These are from a gen 1 22 sct tuning kit.
