MountainStorm
**************Currently Out Of Stock With No Restock Planned**********************
New Vendor here, but not new to vending my products and services. I have an established PayPal business account under rw_keeton@yahoo.com and I prefer to send invoices. All RCC rules of conduct apply. All payments will be for "Goods" and all goods shipped will receive automatic tracking.
First Thread in the Vendor Sub Forum. I wanted to make sure I did it right. I'm a tradesman. I prefer to handle everything in a transparent and workmanlike manner.
The Product for Sale is a Tire Press to facilitate mounting tires on rims. I sized it to work with 2.2 Crawler Tires but it will work on other sizes. As long as the maximum outside diameter of the compressed tire does not exceed 7" the press will operate as intended.
Operation is simple. Insert tire with foam(s) and rim between the Lexan plates and compress it against the work surface with one hand and tighten the knobs with the other. Once tire and rim are in proximity the operator will be able to work with both hands to mount the bead lock or glue on the tire.
Construction is rugged. Two precision routed and drilled 1/4" Lexan plates are put under pressure using stainless steel 5/16-18 hardware and hand knobs.
Dimensions might be handy to know. The plates are 1/4" Lexan precision routed to 7.75" in diameter with a precision routed center hole 2.88" in diameter. Bottom plate holes are 5/16" equally spaced 1/2" from edge. Top plate hole are 3/8" same same. Knobs are 2" 3 Lobe Phenolic with Brass inserts with 2" Steel Fast Lock knobs as an option. All hardware is stainless steel except the chrome plated brass acorn nuts.
Needless to say I have tested this press extensively and I will stand behind it 100%. Anything I make or sell I warranty.
I offer three options.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F853%2Fx4dy.jpg&hash=103db34e80dab370400f7d73a9ae6ac1)
DIY Plate Kit. Top and Bottom Lexan Plates ready for hardware. No hardware included. $30 shipped Priority in the USA. rw_keeton@yahoo.com to request an invoice.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F834%2F419i.jpg&hash=b2e2a254e5ebfe260f0c4bf42d2496f0)
Tire Press. $65 shipped Priority in the USA. rw_keeton@yahoo.com to request an invoice.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F513%2Frbyr.jpg&hash=63aa5e3b64a4b116a1d440821d9cea2a)
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F823%2Fifhw.jpg&hash=15b2ba3d5799c2e1dd16c1acf5a181a1)
Fast Lock Knobs Option: Add $15 to your Tire Press order. rw_keeton@yahoo.com to request an invoice.
Here are pictures of the goods.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F24%2Fi7v9.jpg&hash=15187893554d00509deb6a7722cccbdb)
This lays out the options for Right to Left: DIY, Tire Press, Fast Knobs Option.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F35%2F5xos.jpg&hash=8afc0b84ffa7531b6588170c7032e509)
Break down of what is included in each Tire Press order.
![](/forums/proxy.php?image=http%3A%2F%2Fimagizer.imageshack.us%2Fv2%2F800x600q90%2F843%2F3m0a.jpg&hash=5cf43b3c126de69bf28964887696bf0a)
The $65 Tire Press with Brass Insert Phenolic Knobs, Lexan Plates, SS Hardware. rw_keeton@yahoo.com to request an invoice.
