Sr.Irie
I am running the 1 million diff oil from Gravity racing.
Here's our install video using the IRIE bellcranks on a GCM Racing TowerPlate. It's great!
https://youtu.be/TYAUWT6tgA4
<IFRAME height=360 src="//www.youtube.com/embed/TYAUWT6tgA4?rel=0" frameBorder=0 width=640 allowfullscreen></IFRAME>
Soo, I picked up the recommended servo horn tlr1555 23T for the Irie bell crank steering kit. According to the above GCM instructional video it should be compatible with the stock ball end that has the shorter thread. Unfortunately the ball end's thread diameter is too large to thread into or penetrate the servo horn. Did I miss something? Should i just drill out the horn and nut the ball end? Any insight would be appreciated Wanna be sure before I drill.
St Irie, any word on if you could build what I am asking about above?
Wes
The way I do it is to use one of the push rods and ball ends that you toke off the cantilever suspension and do not use the stock ball ends and cups at all. GCM was showing the ball ends with the stock servo arm. With the Losi arm and my steering you can use the regular ball ends and rods that are everywhere else on the truck.
Picture of mine
Hope this helps
I am wanting to run some Gmade Piggyback shocks I think. I am not real big on the straight up shocks on an IFS setup for tuning, dunno why, maybe its just the looks. I dont know.Well I know I could and if you are a patient man I may be able to, but right now any spare time I have not producing kits and keeping up with orders. I am working on some new stuff and redesigning some old. I do this as a hobby so to start with I do not have allot of time allotted to it.
I can see what I can do, what shocks did you want to run.
Oh and sorry missed the first post I over looked it.
Mine is clearing everywhere just fine, and I'm using the stock ball cups for the drive rod also.
Keep in mind that a servo change will mess this around a bit also. I'm still using the stock servo, although it has just died, and everything was fitting perfectly with stock parts an stock servo. With the servo change, the horn position is slightly different now, and I may have to either move the servo back a bit or change the horn now to make everything work out clean.
