The final drive speed of the HPI Venture SBK is a bit spicy for my liking - furthermore it has no overdrive.
After speaking with Mike at Mike’s Tiny Truck Shop (youtube) - He was able to guide me on the gearing requirements.
It was determined that the Team Garage Hack Creeper-T Transmission (and Ali express clone) would be the appropriate final drive ratio, but also provide a 30% underdrive to the rear. The Stock T-case Ratio is about 1.5:1 and the creeper-T and Chinese knock off is 1.90:1 - So about a 28% reduction to the front axle and 77% reduction to the rear.
I set to work creating an adapter plate for the HPI Venture skid plate so I wouldn't have to drill any holes or modify the stock parts (I hate cutting OEM parts and making them weaker)
I've got to lube up the T-Case and loctite the screws, but the initial test fit looks good. The angle on the dog-bone shaft from the trans to the t-case is more than I'd like, but it shouldn't be a big deal to put a universal joint shaft in there if it looks like it's wearing too much.
The adapter plate can be found here: Printables
I'll update this when I get some more testing done on it: Things to do:
- Add metal inserts for screws so they don't get ripped out if it gets warm, or stripped from going in and out too many times. (You can also use longer screws and nuts on top if needed - I have concerns about how much space is available for inserts)
- Have the plate printed in SLS Nylon for strength
