WRXronald
Ok hey crew, I'm usually over in the Large Scale rigs forum or under a rock somewheres..... But like the rest of you prolly, we all love a cool micro that just goes in the back pack for a walk with the fam at the park and not a care in the world if it breaks on the trail!!!
I give you.... FMS FCX18 ---- how it should have been in the first place lol!!!!
MEGA WIDE STANCE ---- +2 Inches overall width --- using WPL Portal axles (all metal gears) and 70mm+ mud tires.
I had bought this rig just to have something incredibly cool looking but stock and easy to thrash and not worry about.... it broke on the 1st drive in less than 20 minutes
I didn't know it only came with plastic ring & pinion. So silly it seems -- they went and upgraded the transmission to all steel gears, also the portal gears are steel. Why leave the ring & pinion to fail on us like that? ? ?
Anyways, I bought the steel ring & pinion upgrade and in the meantime a set of WPL Portals that seemed junky and I got a refund for --- I decided to see what they can do by going thru all the gears with a fine tooth comb and a plethora of marine grease ----- they're actually pretty darn good overall --- I'm not mad at them.
Fitment was tricky here and there but not too bad --- mounted shocks on the chassis rail for a quick ride height boost about similar to 5 inch lift.
Chassis mounted servo setup --- looks good and finally got it working ok. Going to upgrade to a better servo though -- metal gear etc.
Slightly shorted front and rear lower links -- maybe had to take them down 2-3mm max.
Other than that -- custom little sandwich plate mod on the WPL axle brackets to accept the front triangular 1-piece 3 link bar up front --- and used the stock drive shafts.
Here is mock up, also currently uploading first drive impression and a little "how to" to the Tube that I will post here soon. And I had it on the rocks this afternoon a bit so will have another vid out tomorrow.
And also already put large tires 74mm on the stock beadlock wheels and will post a nother vid of that in coming days. I think it looks best with the stock wheels and even bigger tires so far --- promise not to keep you guessing on it for too long!
Quick Mock-Up short - -
Quick test run on the bench - -
