Too late for me, will put my money in my Poison Spyder and build it up . If I kept telling my customers I was going to show up and didn't, I wouldn't have a job...... simple?Did anyone notice that Tower's shows the Yeti as "Mid August" now?
Same exact tire and size the blue poison spider wraith comes with but a softer rubber.
Yeti is coming with r35 compound tires? Kind of surprised, the stockers from poison spider did really well for speed and loose dirt, perfect for yeti. My r35's are much better on the rocks but way too soft for high-speed.
That's what tower has as a spec. I think they are to soft too. I think the r35 maxxis would have been a better tire. Stiffer and you see them out in the 1.1 u4 scene.
I wanted to clarify that the Yeti is NOT coming with the stickier R35 compound BFG Krawler tires, it has the RTR compound tires.
It looks like Tower has updated the specs to correct that mis-information.
It just makes u not look very intelligent!
do you people ****ing read before posting? christ almighty... :roll:
the front diff is open, as has been stated in probably all of the unnecessary threads that have been started.
Ok calm down man, I don't have time to read through every single page on threads. And thank you, you answered my one and only question...
Badger could you confirm the eye to eye on those rear lower links? Not listed in the ole manual. thanks
Is it just me or does anyone else think Axial should've used Badger's video of the Yeti soaring overhead instead of the one they made with the porn music in the background?
You can never go wrong with porn music. "thumbsup"
If you have more questions (that you may have not thought of yet) check out the first post in my disassembly thread. It has all the specs and details in one place. "thumbsup"
http://www.rccrawler.com/forum/axia...axial-yeti-rock-racer-disassembly-thread.html
I can't wait for this thing to come out. Yes I will be getting it lol. hey badger, is the front IFS differential locked or an open diff? I was wondering this the other day, if it's an "open" diff then the use of heavier diff fluid is needed. I'll be upgrading that rear ar60 to full aluminum and replace the bearings were the pinion gear is with bushings, I have seen those bearings blow up under high amounts of power. Thanks, - axial 4x4 crawler
P.S.- For those that aren't talking about the YETI or this thread in general, then please stop. It's so annoying to hear stupid comments on a thread like this, especially one made by badger.
