DowntownScience
Is this necessary for front wheel clearance or can it be brought in a 1/2" on each side?Wider wheel hubs.
Hey Badger is that Axialfest 2013 Terra-X mud I see still on your PSW?
My Poison Spyder Wraith width is 9.25" from hex pin to hex pin both front and rear.Wraith specs = Width:280mm (11.02")
Yeti specs = Width: 12.3" (312mm)
"thumbsup"
Yep. :ror:"thumbsup"
On the width:
Just to get an idea, i fixed a couple of Wraith wheels&tires to my EXO's front and compared. 2.something cm difference. So, the front of the Yeti is, basically 1:1 from the EXO, and a bit wider than the Wraith.
It's width will help tremendously when at speed. Something that's a decidedly tricky problem with the Wraith. Crawling will only be hampered by the track you choose. It needs a bitof space, but só does a TXT-1 based crawler....or you could just hammer the throttle and slam your way through/over any hindrance (my preferred method) ;-)
Does anybody know about how long the Basher type run time on the Yeti will be? With say a 5000 mha. 3S Lipo battery in the stock out of the box condition. Can't wait till mine shows up!!!!!
9.78 minutes exactly.
What C rating? How can we answer your question without all the information?
Did anyone notice that Tower's shows the Yeti as "Mid August" now?
Well I guess you wont be hunting yeti's any time soon then.:mrgreen:
I heard August 15th.
Is it locked front and rear?
