I have had my Yeti for 2 months now and I have thoroughly enjoyed it in its mostly stock form. I am not a racer, in fact this is my first go fast rig in quite some time. I have been lucky enough not to break anything so far, but winter is here and its time for some upgrades, so I thought I would start a build thread.
up to date photo 14-02-2017
Here is a list of parts used to date:
Axial Parts
AX30836 Axial Aluminum Servo Horn 25T (Hard Anodized)
AX30429 Axial Wraith 12mm Aluminum Hub (Black)
AX30213 Spring 14x90mm 1.32 lbs/in – Red
AXA1423 7x30mm Post - Grey (2pcs)
AX31165 Machined 4 Link Mounts (Hard Anodized) (2pcs
AX31166 Machined Shock Mount Plates (Hard Anodized) (2pcs)
AX31156 Machined Adjustable Motor Mount (Hard Anodized)
AX31169 Machined Body Post Mount (Hard Anodized)
AX30811 EXO Machined Aluminum Front Toe Block F1 (Hard Anodized)
AX80100 Axial Chassis Guard/Toe Block Insert Set Fr/Re EXO: Used for Toe Block Inserts
AX31170 Machined Front Shock Tower (Hard Anodized)
AX31140 Clear bodyshell
AX31162 Axial Steel Spur Gear 32P 60T Yeti
AX30395 Axial HEAVY DUTY BEVEL GEAR SET 38T/13T
AX31164 Machined Slipper Plate (Hard Anodized) (2pcs)
AX31068 Slipper Pad 32.8x15.2x1mm
AX30385 Diff Gasket 16x25x0.5mm (2pcs)
AX30830 AR60 OCP Machined Link Mounts (Hard Anodized) (2pcs)
AX31167 Machined Sway Bar Clamp (Hard Anodized) (2pcs)
AX30829 AXIAL AR60 OCP MACHINED LOW-PROFILE DIFFERENTIAL COVER
AX31172 Icon 67-90mm Aluminum Shock Set - 10mm Piston
AX31136 Icon 87-125mm Aluminum Shock Set - 10mm Piston
AX31173 Icon Aluminum Shock Damper Set - 10mm Piston
AX80045 Axial Light Bucket Set (Black)
AXA1417 Axial Spacer 5x6mm Grey (6)
AX30222 Spring 14x70mm 3.55 lbs/in - Super Firm (Blue) (2pcs)
AX30382 EXO Steering Kingpin (TiNi Coated) x2
Vanquish Parts
VPS01042 VP .225 SLW wheel hubs
VPS01043 VP .475 SLW wheel hubs
VPS06224 OMF 2.2 Outlaw II Rear Ring Blue x5
VPS06207 OMF 2.2 Front Ring Silver x5
VPS06104 OMF 2.2 Original Beadlock Blue x5
VPS06252 2.2 Wheel Clamp Ring x5
VPS5000 Vanquish Scale Wheel Screw x3
VPS07351 VP Trailing Arms Silver
VPS07201 VP Yeti Titanium Rear Upper Suspension Link Kit
VPS07232 Yeti Steering Rack Silver
VPS07200 Vanquish Products Yeti Titanium Front Link Kit
VPS07230 Yeti Double Sheer Steering Rack Kit
VPS06553 Axial Yeti / EXO Steering Knuckles Blue
VPS03223 Vanquish Wraith & Yeti Aluminum Lockouts Blue
VPS04302 AXIAL WRAITH / YETI AXLE SILVER
VPS04312 AXIAL WRAITH / YETI HD TRUSS SILVER
VPS04740 AXIAL OCP AXLE BEARING CAPS SILVER
VPS07811 YETI BELL CRANK CLEAR ANODIZED
VPS07771 YETI FRONT SHOCK ADJUSTER CLEAR ANODIZED
VPS06762 VP Rigid Industries 1" LED Light Bar (Silver)
VPS06756 VP Rigid Industries 4" LED Light Bar (Silver)
VPS07870 Yeti VVD V1-HD 4mm Stubs Front Axle Set
VPS07891 Yeti Front Skid Plate (Silver)
VPS07721 XD Series Center Hubs (2) (Silver) x2
VPS07080 Aluminum 12mm Clamping Wheel Hex (2) (Silver) x2
AX31435 Aluminum Shock Spring Retainer 12mm Black x3
Electronics
010-0145-00 Castle Creations Mamba Monster X ESC
011-0108-00 Mamba X Series Sensor Harness
HH-PLLR-BL-PRO-3500 Holmes Puller Pro BL 540XL 3500kv
OMG ST-BF30S Full Aluminum Waterproof High Torque Digital Brushless Servo
CSE010-0004-00 Castle Creations 10 Amp Adjustable BEC
CSE011-0053-00 Castle Creations 6.5mm Polarized Bullet Connector Set (Male/Female)
5050-3S2PD SMC Factory Spec 11.1V 5000mAh 50C Deans x2
HEYRCSW1EXT HeyOK External Power Remote Switch for LED Lighting
EBAY LEDs and resistors
Other Parts
X4R-VU4-S X4 Racing 2.2 Voodoo U4 Tire - Silver Compound
CRI-F008 Crawler Innovations Single Stage Closed Cell for 2.2 Tall Tires
CRI-5021 Axial Yeti 1:10 Front Foam Bumper Insert
RPM70472 RPM Front A-Arms EXO Buggy
RPM73622 RPM ESC cage mamba monster X
SCP160B06 Hot Racing Blue Aluminum Suspension Pivot Balls (20)
AE1402 Associated Factory Team Turnbuckle 1.375" 35mm (2)
TRA5039 Traxxas Differential Oil (500,000)
TRA1675 Traxxas Oilite Bushing Set (10)
MIP14390 MIP X-Duty Rear C-Drive Kit, Axial Yeti
GEASCA060 Gear Head RC 1/10 Scale Yeti Slim Line Roof Rack with Light Bar Mount
DMGSK10003 DMG Yeti rear diff skid plate
SPTSTA31102RS STRC CNC Machined Aluminum HD Rear Cage Stiffener (Silver) Yeti
SPTSTA80034S STRCYeti Aluminum Shock Collar w/O-Ring (4) (Silver) x2
SPTSTA31105BK STRC Aluminum Chassis Brace (Black)
HH-TH-SPOOL Holmes Hobbies torquemaster locker
RRP8716 Robinson Racing Pinion Gear Xtra Hard 5mm .8 Mod 32P 16T
WERTYMADE Custom front bumper
YEA-YA-0352 Yeah Racing 1/10 Crawler Scale Accessory Set (Fire Extinguisher)
Judd Rummage Concepts JRC tire strap black
Here she is posing with my Dingo when I first got her.
One of my first upgrades was wheels, I love the modular scale look of VP's OMF's but they are notoriously difficult to mount when using a large closed cell foam like the Crawler innovations. So I took some scrap plywood and a 3" hole saw and made this little jig that made installation a breeze.
Axial Parts
Vanquish Parts
Electronics
Other Parts
