Sorry I haven't posted any updates for a while, I've been so busy on the Grand Cherokee build and also non RC stuff. (Ugh!)
I haven't even started the Grand Cherokee thread yet, but I will.
Still have to post the rest of this build first.
Okay, so this post will cover the headlight/tail light install and the light unit/opto switch.
Here are pics of the tail lights mounted in the rear section of the interior that was not being used after it was cut off from the front section.
It was later glued in place under the bed with ShooGoo.
Headlights / Tail lights installed.
This is the
RC4WD light unit that I start with.
I wanted to run all the lights from the truck's Lipo battery and be able to turn them off and on from the Radio's channel 3 switch, so in order to use the
RAM Headlights (which run at a higher voltage than LED's) with this light unit, I removed the resistor from one of the 12 plug socket circuits on the light unit so it will pass full battery power to that plug for the Headlights.
I marked that plug socket so I will know not to plug any LED's into it and burn them out by mistake.
You can see the resistors on the back of the circuit board. (R1 - R12)
I removed the one for the number 5 socket (R5) and bridged the gap with solder to complete the circuit.
This is the
RCEXL optically coupled engine kill switch that I use any time I need a receiver controlled on/off switch.
The switch comes with instructions on how you can modify it to use the receiver power to run the load instead of a separate battery input, which is what I want, so I did the mods (simple solder bridges) and also removed the "power on" LED since it won't be seen. I also switched the male "power out" lead to the female lead I removed from the old "power in" location so I can plug the light unit right in to it. See pics below.
This is the setup all finished. Just plug it into channel 3 on the receiver and you have a cheap light system that can be turned on and off from your radio.
