Comanche Build - Very Scale - SCX10
Great vid and build! Look forward to seeing it in action. :)
Thanks. Trying to stretch the imagination a little.
Should have a trail vid soon. Wanna stay outside the box again.
Make sure to sub my Youtube channel (below) if you aren't already so you'll be notified. "thumbsup"
I'm going to use the "open" diffs in this build too like I did in the Cherokee but I have found a way to limit the slip in the diff, and it's so simple.
It did add a significant amount of drag on the side gears when I put an axle in and tried to turn it. I will put this in the Comanche diffs and see how well it works like a real Limited Slip Differential. (see pics below) "thumbsup"
Im curious how these work Im thinking about putting one in the front of mine. What are you using the O-rings for?
Yes, one in the front might be a cool idea. I tried them in both the front and rear but as light as these rigs are there was just not enough traction. As might be expected, it turned super smooth with no bind at all as compared to lockers, but no good for low traction runs, etc. A lot of RC trucks come with an open diff in the just the front and do quite well that way.
I never had a chance to try it out since I pulled them both out at once.
The O-rings are to keep dirt, etc. out of the diff. they seal on the axle as you can see in the diagram.
BTW, I don't think the spring I added really did much to help limit the slip.
Happy trails.
Okay, well I ordered the parts and will see what I can work out maybe a combination of really thick grease and the spring will help. I have worked on 1:1 LSDs and may apply some stuff to these little diffs. Very cool build BTW."thumbsup"
That is crazy realistic!!!
Thanks! I have a bunch more projects like this in the works so stay tuned.
Also here is the newest video just uploaded today. "thumbsup"
<iframe width="560" height="315" src="http://www.youtube.com/embed/d2kAPmSPckw" frameborder="0" allowfullscreen></iframe>
Well my diff gears got here today. I did the same thing with the spring but I stuffed extra o-rings on each side of the side gears, and it seems to act like a real limited slip. I also packed it with wheel bearing grease. In the front axle It seems to wheel a lot more like a 1:1."thumbsup"
Nice! Just in the front, right?
hey there. I'm just getting into rc cars. i love your builds they look great. I am a cherokee enthusiast. I currently own two real jeep cherokees.
I was curious as to where you buy your parts from and chassis?
Hey there.
I also have a real (1:1) Cherokee. That is what I copied for my RC version.
I started with an Axial SCX10 (Dingo - builders kit) for the chassis, and a Pro-line Cherokee body, both from tower hobbies. I joined their super saver club for $9.99 and save a lot on purchases from them. (just have to order stuff together to save more)
I use RC4WD now quite a bit for trick stuff. They make some really amazing RC truck parts.
Also RPP Hobby is a great place to get RC stuff and they also carry a lot of RC4WD parts, as well as many other vendors.
Happy Building!
