Will I hurt a 13t hh crawlmaster using a 13t or 14 t 48p pinion on a 87t spur also 48p
No, I run the same setup but with under drive in axles and it crawls like crazy. I cant imagine having any more low speed control.
Harley i have burned up two motors in two days in a spawn which is geared 56/12 in 32p. Both a 20t and 27t axial on 3s. I've got a 15t dynamite laying on the shelf what would be a good setup gearing wise
I ordered Ckrc Next Level 32 Pitch 54 Tooth Spur Gear 14 Tooth Pinion Kit , and 32 Pitch 60 tooth Spur 9 tooth Pinion Kit .
What kv / turn brushless motor would be a safe choice?
Thanks all
The best choice is a 4 pole sensored motor in the 3000-3300 KV range.
I would recommend the holmes hobbies torquemaster br-xl if you like a brushed esc. It's justba little over $100 and is a very good comp proven esc. You should be able to pick up a esc and good motor for under $200.Harley,
Is their a motor/esc combo you recommend that is under $200? I spend most of my budget on Vanquish Products.
Thanks
Harley,
Thanks
What gearing are people running for gearing with a crawlmaster 13t on 32p? I currently have the stock gearing from the wraith spawn 920/56). Is that too high? I'm assuming it is..
Never heard of a 920 tooth pinion gear :shock:, but yeah 920/56 sounds a little high. :mrgreen:
I'd start around 10/56 and monitor motor temp.
Little high?Never heard of a 920 tooth pinion gear :shock:, but yeah 920/56 sounds a little high. :mrgreen:
