Little high?
Just a little, might want to cut it back about 909 or 910 teeth.
Little high?
I forgot to shift+9![]()
I got 3 packs through on 20/56 but its quite cold here right now (30* F) so I haven't had issues but once it warms up I'm assuming it will be a bit too much. It's in a 1.9 7ish lbs wraith running 3s.
48p or 32p? if 32p start with 56t spur and a 10t pinion...if 48p go with a combo that will give you something between 5:1 and 6:1.....
Agreed...and would definitely recommend 32p on 3s, 56:10 to start with that motor.
Great, thanks guys. And just to be sure it's the BRUSHLESS Trailmaster I'm talking about, and not the older brushed Trailmaster motor John used to sell?
Yup. I run a ROC 412 3100 on 3s, which is very similar to the Holmes brushless. Ran through pinions like mad with a 48p RRP slipper. Switched to the 32p RRP slash slipper, and it's been great ever since.
Will the stock slipper work OK with this motor, or is it something that I need to upgrade right away? Also, is a plastic spur OK at first or do you need metal one with the HH Trailmaster?
I was running the RRP slipper from the get-go, so I'm not sure how those would hold up. If I had to guess, I'd think that the stock slipper and a plastic spur are not likely to hold up terribly well. A delrin spur would probably do better. But that's me guessing.
Hey Guys went ahead and read a good bit of the thread but have not found the answer for what would be a good spur/pinion for my Wraith.
Its a stock RTR with the 20T motor with 2.2 RocK Beasts on 2s. I want a mix of good crawler and some fun rock racing type speeds (not competitive)
Will a 56/12 work or will that heat the motor too much with the heavier tires?
I just put a 54 and 11 32p gears into mine on stock tires and motor and 2s lipo. I noticed a little more gear noise, is that normal with the 32p gears? Mesh isnt too tight, the motor is adjusted in all the way and its not that tight of a mesh. I bought the traxxas 3454 spur gear and had to drill the holes I used out with the next step up drill bit to get the holes to line up with the holes in the slipper but it fits and runs straight.
So far I have lost a little speed but it does seem to crawl a little better with it. Cant wait to get it out again soon and try it out some more
Heat - if geared right neither will be too hot. I have a Holmes BLS540 and I have not found a gearing setup that can get temps below 150* F. JRH says his motor can handle 160 so it isn't damaging the motor. However I just feel more comfortable with my roc412 running at 90*, same gearing in the same rig.
