Re: Choosing a motor and ESC for your Wraith
Mamba max pro SCT edition 2400kv. Thought it would be perfect but the motor is too long and hits the lower rear link connection on the skid. Damn!
Hi there i have manage to put that combo without any issues on my wraith.
this is what i did.
first. you have to dremmel a bit the lower rear link. next you have to buy 8 washers and 4 screws longer than stock 0.5mm (to tight and so get thru the hole. i will explain more ahead).
Now you have to disassemble the transmission of the skidplate, then this is what you are going to do.
Put 2 washers betwen the transmission and the skidplate of the wraith (i put mines with a bit of superglue just to hold it until i tighten the 4 screws.
remember 2 washers for screw, and buy another set of 4 screws longer than stock 0.55 (aprox size of the washers) to give it hight so that it doesnt hit the lower link.
after that, dont forget to put a bolt inside the transmissions to hardened them.
mount again everything and plug the motor wires like this, red to red, white to black, and black to white.
I am running mine on 2 s lipo 5000mah 50c, it gives about 2 hours run without any issues, full throtle in a place with no hills, flat dirt and a litle of sand too.
I moved the battery up to the front, and put the esc where the rx was, and the rx i put it in the ground of the passenger seat. Remove the plastic betwen the dashboard and the shocks to fit the battery because i put a 4 mm plug direct sodder to the mamba max pro and turn the battery to the front to plug the wires directly to my vennon hardcase 4 mm female. In the future maybe i will put another 2 s lipo 5000mah 50c in series to get 4 s, this one now in the back in the original place
. but i guess before that i will have lots of things to upgrade.
the thing i am feeling right now, its a litle cogging when you are starting to move, and a litle top speed, i would like to have a litle more top speed, but that i can make it by 2 ways, gear it up and also put 32 pitch gears or i will buy a 3s lipo and keep the 2s for trailing, or (what i want is get another 2s equal to mine to put them in series and make 4s) (i am running with stock in this setup with no issues) and the motor doesnt it gets hot, either the esc, IM IMPRESSED, EVEN ON SAND FULL THROTLE, ALWAYS COOL AS ICE, my fear was that because i live in brasil in the city of fortaleza and the average temps here are about 28 degrees (average) but its not dificult to have a 34 or 36 degrees.
best regards if you need pics let me know
cravo
