The 12t is just not a good choice. A 21t would be better. It has nothing to do with the ESC. YOu should also check the driveline for any other binds.
Is there any low-budget sensor combo for crawling and mid speed running?
My car is RTR Axial Wraith.
I really appreciate if someone can help me! :roll:
I have not found any good low cost options that are decent at crawling. Most of the issue is usually based around braking and reverse types. The Castle controller is really worth the extra money because a half price controller is usually about worthless :x
Currently running a 20t Crawlmaster with an FXR on 2s, i have no heating issues whatsoever and like the setup. But could use more wheelspeed
Can i just jump to 3S without changing nothing. I mean heat shouldn't get higher as i will pull less amps with more voltage right? what else can i expect?
Is anyone running a 45t motor? I think its gonna be a little slow for my liking but it came with the fx-r I got so I thought I would throw it in. I looked through the thread but didn't see any recommendations for gearing with a 45t. The stock spur is 80t right? What would be a starting point for the pinion?
im looking into buying a castle creations sidewinder SV2 or sidewinder SC first of will the weight of the car matter and 2 do i have to change my reciver? buddy of mine has this same system but had to change his radio and reciver will i have to do the same? im running the 2.4 that axial gives you in the RTR version of the truck
This may not be the ideal place to ask this question, but here it goes. I read in another thread that a Pro 4 3300 has the same amount of torque as a 35t brushed motor. Just curious if that is the case? I am running a HH Torque Master Pro 25t and was considering a Pro 4 3300. I am more concerned about torque/low end power. Thanks
I consider it the best choice for the Wraith. You just have to tame your finger down because it will destroy parts.
I'm so confused after reading this entire thread. I just bought a used bone stock Wraith with a 2s 4000 mah stick battery pack. I'm mostly crawling and trail running. If I just change the motor and gearing what should I go with and I want to stay brushed? I have a couple 55 Turn motors laying around but didn't read about anyone going that route. Please help!!!!!
