Hi there, i am a newbie and i want to know what the best motor to pair with a mamba max pro esc, i want to do some slow crawl and a lot foffing with sand padles, so i am buying 4 rims with a wider offset to make the axles wider and have more stability when it turns.
I would like to know what do you suggest.
I am considering tekin brand, but i am very concerned with heating issues, because where i live the average temp is 30 degrees so i would like something that will run cooler even with the load of running in soft sand uphills.
i was considering the sc4x motors from tekin
MOTOR P/N TURNS WATTS KV MAX VOLTAGE ROTOR
Redline SC4X 4.5 TT2243 4.5 900 4,800 2S / 7.4V 12.5mm
Redline SC4X 5.5 TT2242 5.5 815 4,000 2S / 7.4V 12.5mm
Redline SC4X 6.5 TT2244 6.5 745 3,400 3S / 11.1V 12.5mm
Redline SC4X 7.5 TT2245 7.5 665 3,000 3S / 11.1V 12.5mm
the pro 4 from tekin also
MOTOR P/N TURNS VOLTAGE KV ROTOR
Redline PRO4 4600 TT2500 1Y 2S 4600 18.5mm
Redline PRO4 4000 TT2501 2D 2S 4000 18.5mm
Redline PRO4 3300 TT2502 2.5D 2S-3S 3300 18.5mm
and the sensored redline
MOTOR P/N TURNS WATTS KV ROTOR
Redline Sensored 2.5 TT2261 2.5 730 11,900 13mm
Redline Sensored 3.5 TT2260 3.5 630 10,800 13mm
Redline Sensored 4.5 TT2259 4.5 535 9,300 13mm
Redline Sensored 5.5 TT2258 5.5 428 7,700 12.5mm
Redline Sensored 6.5 TT2257 6.5 404 6,700 12.5mm
Redline Sensored 7.5 TT2256 7.5 352 6,100 12.5mm
Redline Sensored 8.5 TT2255 8.5 295 5,300 12.5mm
Redline Sensored 9.5 TT2254 9.5 261 4,900 12.5mm
Redline Sensored 10.5 TT2253 10.5 243 4,500 12.5mm
Redline Sensored 13.5 TT2252 13.5 201 3,500 12.5mm
Redline Sensored 17.5 TT2251 17.5 131 2,500 12.5mm
Redline Sensored 21.5 TT2250 21.5 88 2,100 12.5mm
So i want to know wich one it will run best with enought power and low temps and with some wheel speed to go up the hills with no problem, i know the sc4x i will have to grind a litle the skid plate but thats no problem. I will be running 2s lipos from vennon 5000mah 50c, but i can also buy another kind of lipo 3s if necessary, what do you advice me?
Other brands may be suggested i just put tekin beacause its a named brand and lots of people use them, i would like to know wich motor, and kv do you recommend me to do both, some crawls 30% and 70% foffing.
Can you help me on that?
thanks in advance
cravo
