bilinvic
I have the ears of the HH SHV500 mounted on the inside of the plate (on the motor/trans side) and the steering link is bolted to the servo side of the servo arm...all is good with clearances.
Dlux axles...?It was the B1B Bomber's turn to go get dirty today. Great run and lot's of fun driving this rig although I snapped a Vanquish front axle today at the inner dogbone. Luckily I was carrying the stock Axial axles as spares; I do like that front axle changes are very quick and easy and the B1B was back up and running in no time at all.
....the clean-up, detailing & maintenance routine with the B1B. It's a good thing I stripped 'er down, I found the three long bolts that go thru the transmission into the motor plate had loosened off and the motor was quite loose. Fortunately, the spur and pinion were not damaged.
Maybe eventually, I have a couple pairs of spares that I will use up first.
Hello, you use what reference for shock absorbers av ar, thank you
