Had another test session last night, first time using the HH PP motor. As expected, the performance was awesome, low end resolution for crawling was perfect and so much wheel speed with a stab of the throttle. I'm geared 12t/56t and may drop down to a 11t pinion as I really don't need that much speed, even for bouncing!
Remember the Incision Axle dogbone pin issue I was having? For shits and giggles, I pressed the pin back into position and then applied a very small amount of JB Kwik around the pin where it exits the axle ball end. Once the epoxy cured, I smoothed the JB Kwik with a file so that the epoxy would not present any clearance issues once the axle was inserted into the front diff cup. After last evenings 2+ hours test session, which did involve a ton of wheel speed, the axle pin has not moved one bit. "thumbsup""thumbsup"
