LOL cause u gave me they key words I was literally ordering one with epacket option from ebay.They are $2.50 each out of china.
does anyone know what type of aluminum servo horn fits the hexfly servos on out everest 10? I don't know what size the spine is, anyone got one from amazon or other source, or have any idea.
25T M3 Metal RC Servo Arm Horn for Futaba Savox Xcore Power HD Servos Red EVV | eBay
Thanks for the servo info will pick up one today at LHS.
BTW I love this crawler but here is what has broken so far, and mods I feel like needed to be made I dont mean this in a bad way because Im sure the same would have happened with a axial by now also. As a matter of fact most have with the guys I crawl with.
New tires- much better grip
Moved weight forward, battery now sits all the way over servo.
Broken - both diffs and case have had to b replaced. They were replaced with axial case and metal diff lockers.
Servo went out but think it was because the wire rubbed on the main gear and shorted it out.
now servo horn.
thats it so far, but it has been four months of very hard core crawling, mainly in large creekbeds at Stone mountain park.
What's the stock pinion? 14t? Will any 14t work?
Stock gearing is metric which i think is 0.6mm. Post above stated 48P pitch but that is imperial so I assume he is tunning an scx10 spur. If you mix the 2 together they might work for a little while then destroy eachother.What's the stock pinion? 14t? Will any 14t work?
This is wrong. we did this test a month ago bro.Stock gearing is metric which i think is 0.6mm. Post above stated 48P pitch but that is imperial so I assume he is tunning an scx10 spur. If you mix the 2 together they might work for a little while then destroy eachother.
After I asked46.95mm
So using the calculator here it puts out 48dp.What's the diameter on the 87t E10 spur?
