Same here, i think the chassis he posted is a short wheelbase chassis if it's meant for the d90 body, but a chassis that is meant for an scx or ax10 will work, I used stock axial links to convert mine also, but that's it, tranny and axles are redcat.
The center skid doesn't match up perfect, and I found the scx10 skid sits low enough the trans case bottoms out on it. I cut the redcat skid so it was just the base the trans bolts to and used it as a template to drill into the scx skid and then used it as a spacerFor the Center skid, did you use redcat's and just mount the straight links on the outside?
how about this to start just to get an idea till i crack them
http://www.ebay.com/itm/Axial-SCX10...989605?hash=item58d3e2f965:g:4nEAAMXQuCdTfsJC
Scx10 frame, EVERYTHING else everest. Can be done just probably won't have the wheel base you want
Sent from my SM-G920R4 using Tapatalk
It had its pros and cons. On level rocky surfaces it was great but on a steep incline there was no preload to hold the front down and it would flip over backwards a lot. I don't have it setup like this anymoreHow do you like the full Droop on the stock shocks?
Looks great, but I'm not sure that tape is going to hold it together. lol
