Steelers fan 44
I'm no where near comp days. Lol. But I just wanted a starter rtr crawler for now. I just ordered a 35t motor, 100mm shocks and axial lockers what can I do to lower the CG? Again thanks for our help jeep.
http://s1286.photobucket.com/user/TakeOffYouHoser/media/027_gimp_zpsebb191dd.jpg.html
http://s1286.photobucket.com/user/TakeOffYouHoser/media/028_gimp_zpsab3e1405.jpg.html
http://s1286.photobucket.com/user/TakeOffYouHoser/media/031_gimp_zpsb8a1743b.jpg.html
... but none of it will go together properly without SOME material removal. It's a necessity. To run Axial axle dogbones you MUST remove material somewhere. Below you can see a stock Axial front axle dogbone in the Everest 10 axle housing. At the left side you can see flange that the bearing would ride against is protruding from the housing end. This is undesireable. In order to fix this you need to remove material from the end that slides into the diff locker. This is only necessary on the one side. The opposite side, shown second pic below, shows the oppisite effect, so no material removal required.
Pictures?
Parts Link?
Thanks
I put 100mm shocks on mine. That droped the link level with the ground
I use 2.2 HB rovers and they were great. Tires made the biggest difference. I did put 1.9 trepadors on it in the end and they did just as good. But there is a loss of ground clearance. The rovers are ballon tires. What I would like to try are some 2.2 chisels. I guy I run with has a set on his wraith. They are tall but narrow like a 1.9 and have a similar pattern as the rovers
The only issue I had that I finally fixed was the lifting of the right front. And all I had to do was play with spring rates and preload. In the end the E10 was dialed in. It would go almost anywhere. And I never broke anything(I did have a steering knuckle come loose once but that's on me).
Sad to say that I have an "Everest 10 no more". For no fault of its own it is now an scx10. Nobody around here runs a comp rig. All scx10 and wraiths. I really liked the scale look of both. I was very hard to strip the e10 just because it preformed so well. The only thing I need to put it back are some axles and some links
Good reviews helped me make up my mind thank you all , I bought 2 for my grandkids for Christmas a boy and a girl 8 and 7 ,they are gonna love these rigs ,,Robert ,,,
No you just need a set of Axial iron cross lockers. Then file the shafts down until they fit snug into the locker. Should be about $30 or less per rig. Part number AX30500.Thanks for the info ,, I will go threw this thread again ,,but from what I seen costs about 100.00 to add a spool for both rigs ,,
Watch this video and it shows you what to do. Just first 5 mins or something.
https://youtu.be/01z7g1leqh0
quick question, the scx10 driveshafts will fit the e10 right? i just busted my stockers and wanted to upograde to metal units, just double checking.
