How so? Every locker designed for axial takes the same shaft size. The only time you would have this issue is if you bought the HSP spool/connect box as it's obviously designed for HSP sized shafts.
No one has it backwards. We all know the HSP/E10 shaft is bigger and needs to be ground/filed dow. But there is no down side of doing this as there are 10 different types and brands of lockers or spools for the axial sized shafts and only 1 for the HSP sized ones. If you have ground down the shafts and upgrade to a spool type locker then you just buy one designed for axial. It will also be better quality than thr HSP and only cost about $5 more.You've got it backwards. Axial shafts are smaller than E10 shafts. You have to grind down the E10 shafts to fit the Axial lockers. No way around it. I run HSP lockers also, they are drop in with no modifications required. More $ but better IMO
No. The uppers are different. just make new ones.So the stock E10 links work well on a scx10 or xtrail chassis?
I know the bottoms should be fine. Its the uppers I am worried about. Would like to know in advance so I can get what I need to build my own links
thanks, me too! lol. im now waiting on a new body and tires to complete my e10 scx makeover. sorry if i missed this somewhere but can the everest tranny be mirrored like the scx? also can the stock esc handle an axial 27t motor? one came with some parts i got and im itchin to replace the stock unit but do like how the stock esc is waterproof.
Hello all I just bought a e10 for myself to get into the world of rc'ing. I have been interested in it for years and finally pulled the trigger. I have read through this post and want to do some mods on the fairly cheap to turn the e10 into a low-profile crawler. Any suggestions and links to how to do the mods would be very appreciated.
