Jeepiac
You forgot to mirror your transmission.
Yes...yes I did
Found a really great deal on a set of lightly used white dot rovers with bead locks with the narrow offset for more turning radius
The more you do the more you want to do
there is an r1 chassis with tranny in ebay at the moment
I don't understand the reasoning behind this mod. Is it to cut down on torque flex? Also, I assume the throttle setting on the tx would have to be reversed?You forgot to mirror your transmission.
The reason they bind is the hex pieces. When the pin is in the slot there is still too much meat between the pin and the knuckle. You need to shave a bit off the knuckle side of the hex.
Impressive. Hard to believe that's a cheapo E10, but they do have a lot of potential. Here's what mine ended up turning into.
Xtrail chassis is what started the whole deal. Mirrored the tranny, 20T motor, used the original servo plate and mounted on the chassis. Never could get the turning radius with the stock axle setup and one thing lead to another and I ended up mounting a pair of R1 portals under it with cv's, aluminum link mounts and knuckles. Did the axle mod and installed Sawback gears in the rear and now the steering aint to bad. Put a set of MIP spline drives in it and ended up sticking a set of Deadbolt RTR shocks on it and the thing crawls like crazy now. High ground clearance, light weight and a set of heavy aluminum wheels and it's glued to the ground. I found a discontinued Monte body and couldn't resist painting it like my 1:1 Monte. Looks goofy, but low, light and wide "thumbsup" Cut down E10 links and the tranny are all that's left of the Redcat at this point. Disregard the purple shocks and Vaterra wheels that were on it in the picture. We've all ran outta parts at times :ror:
