Why do you need to stiffen the chassis? What are you doing to the poor thing?
No harm done. I noticed the Pangolin has chassis braces at the upper shock mount so It got me thinking :idea:
ok I will be ordering mine soon...maybe this weekend
I hear one mention of a slipper clutch... I am guessing not having one is not an issue. that being said the stock trans must hold up pretty well? cant find aftermarket gears...just the whole trans for $15
Anybody run brushless? I have a 25.5t novak that is collecting dust that I need to do something with.
my plan is to keep it stock at first...just to see how it does. Looks like the stock bushed is just my speed. the first thing will be the $15 Iron Cross lockers with the stock shafts. I am not planning any steering mods yet so I hope I get use out of the stock shafts for a while. If I have shaft issues will have to install cvd's.
From what I have read lockers and shafts, and aluminum knuckles will make it pretty bulletproof
Foam and tire trimming helps but a new set of tires are a must
Looks like the stock shocks are ok but needs to put in some droop
If the stock shocks give me issues will have to buy new ones, and if i do that might go more scale with the tcs xtrail chassis and 90-100mm shocks
I will add my MT4 tx
So the way I look at it I can do everything I want with new tires and end up with a stronger better rig for less than a Stock Axial.
but then again this is not about the money. Its the journey not the destination. taking the underdog and making something competive
