IMPORTANT
At tech inspection each driver will receive a drivers packet. In the packet there will be 6x different colored score-sheets, raffle ticket, Simple-Green Coupons, and sticker with their drivers # on it.
Colored Score-Sheets : should already have your information on it. Each sheet goes to a specific course. When its your turn to drive you will given the sheet to the score keeper to record your scores. After the run you will sign the sheet, and will be placed in a container. The sheet will be routinely taken to the score tent, and post...HOPEFULLY ONLINE IN REAL TIME through Google Docs. (May be viewed on laptop, smart phone, or other web enabled device.
Raffle Ticket : is used to claim prizes through out the day. Driver is responsible to keep up with their ticket the ENTIRE DAY. There will be rafffles until the end of day. You lose your ticket its gone.
Drivers # Sticker : must be placed in a clearly visible location. Failing to do so may result in a DQ.
Drivers are expected to move through the courses through out the day. Currently the plan is.....
Drivers must COMPLETED 3 Courses by 12:30. Note that it says completed not just in line.
Failure to do so will result in Course DQ (50) on the appropriate number of courses starting with first course (not yet run)
Example:
At 12:30 Colby has ran 2 courses. Course 1 and Course 4. He would get a 50 for Course 2.
I know this sounds harsh, but its the only way I know that keeps all the drivers from waiting until conditions are "PERFECT", and still give them the choice (Free Crawl) to run courses in the order they want.
