Hilux body!
I got a used hilux body to put on my SCX10 and read a thousand posts about how to mount it, but there were very few that had any good pictures. I decided to make a u-shaped mount over the top of of the front shock towers and velcro at that point. Then I started working on a side body mount. I was thinking about just brazing something to my existing rock rails but then I decided to start fresh. For one thing, the existing ones were a little wide for the hilux body. Plus this way I could switch back and forth between bodies.
So here are the pics...
Side body mounts
drilled mounting plates and mounted body, plus added first rail for sliders
started in on a rear truggy frame since I don't have a bed
Added some bracing
End results around 2:30 am last night...
Now I need to figure out what I'm going to do for the rest of the truggy frame work. At this point everything is bolted to the frame rails and I plan to keep it that way, so I need to work that part out first, then finish building the tubing.
Side body mounts
Added some bracing
