so what happened to the video?
Sorry man - the rig is done and has pulled two friends in the wagon half way up the steep driveway - 275lbs, from a standstill. The servos have now failed. Not sure, water I think, the front goes 100% to the side, the rear goes twitchy like nuts, I don't think its gears, I do think its water again. (deep water run in river, see vid).
Once the servos failed after the water run, I put the rig on the shelf for last 2 weeks.... been building a new BIG RIG to put all SCX6 would-be "Rock Crawlers" to shame. Alas, The SCX6 Clodbuster Beastie has become massively portly and now at 33lbs, 3.2ozs, she really is not going to be able to outcrawl or even come close to the FOC Rock-crawler low-slung dedicated SCX's out there. The CLOD is now going to be BIG MUD, BIG SNOW, BIG HAULIN, BIG HILL CLIMB, and some ROCKS, but not rock crawler dedicated once I get the servos fixed and water-proofed this time with polyurethane coatings.
Instead of the SCX6 Vitavon monstsrosity i was planning to build, (too pricey, too heavy, parts availability etc, excuses excuses) I wanted to repurpose what I already had on hand and get to building NOW. And was so TIRED of my old tired TRX4 and 1/10 scale rigs -- everybody has one. And the axles had seized finally (front bearing on bevel pinion is so seized that even torch RED hot with NUT BREAKER will not release it, the bearing race is toast). $30 for a set of ring & pinion and bearing kit for front TRX4 axle. SO DUMB.
So, the TRX4 LC70 KillerBody rig I had on the channel is no longer... I auctioned the hard body, bought a bunch of aluminum L channel, steel tube and rod, and 4mm heims, and new axles, and got to building!!!
On Ali, for $35 per axle, you can now get CAPRA style very wide 225mm hex-to-hex portal axles. Come with ROBUST 7075 housings, hardened steel shafts, tool steel U-Joints, --- serious legit ok quality stuff!!!! I added 40mm of widening per side, 80mm total. WOWOWWW. And I can say they are taking a PHWOMPING the last few days no signs of death yet lol.
Ended up with 22inch wheelbase, 15 inch trackwidth wheel to wheel, 12inch rear lower 4 links in steel, upper links in aluminum, all steel M4 heims ball joints, 14.5inch rear drive shaft pieced together with steel half-shafts and shored up inside a single long tube 16mm 6063 aluminum filled with JB Weld and the steel half-shafts stuffed thru it. Custom steel skid plate extension and steel rod ladder stiffeners throughout. Metal 2-speed tranny with hardened steel gears. Running on Redcat Rock Crushers 8inch tall tires with my custom inflatable tire mod setup on Scooter inner tubes on 40 series RC4WD Aluminum beadlocks, custom cut & arrowed by me into pizza-cutter like tires.
Longer wheelbase than SCX6, long overall than SCX6, slightly bigger (essentially same) track width as SCX6) and again, taller tires than an SCX6!!!
Comes in on the mega diet at just 19lbs running 3s lipos 5000mah. Was looking to keep it light weight and ready to CRAWL!!!!
So far is showing it will be an AMAZINGLY CAPABLE crawler, has conquered terrain at my house that nothing else has been able to so far, GLUED to the EARTH.
Running Turnigy Aerostar 4250 Big Block Outrunner brushless motor on Rhino 80Amp Esc up to 5s and 1000watt capable motor, 375kv --- mega slow Sine wave setup with AM32 programming, mega torque for days!!!!!
It did do 2.1 miles round trip with the SCX Clodbuster on the dog walk one night a couple weeks back, its putting in some work so far.... The transmissions are holding up just fine, still had to carry it home the last 100yards do to a drive pin falling out the CVD cup near the end, needs red loctite---- BRUTAL long walk with 33lbs on your head let me tell you, you think several times about where you're driving this truck, because if it fails on the trails, how is it coming home????!!!!
SCX Clodbuster -- hitting the river (and trashing my 1/5th scale servos!!)
---> can start in the 11:30 range if want to skip to EXTREME deep water scene....
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Guess I'll put the new build in another thread -- I have a couple vids on it and will keep 'em comin' for both rigs very soon!!!!
The building madness just never stops....... its whack, its rudimentary, I don't have time for perfection, but as far as i'm concerned, these rigs are just the bees knees and what I was planning for so far!!!! Very pleased with them, now that I have two up and running (just about), Ferp your invited. Head to Ohio and lets do some riggin' together!
