Mike Flea
Rear is longer because it protects the yolk on the leading end of the pumpkin?
would be my guess...Rear is longer because it protects the yolk on the leading end of the pumpkin?
Nope, they slide right in... somewhat tightly as they seatDo you have make modifications too the axles so the Boom Racing Tubes fit ??
The XR10 Chubs/Sknuckles I'm using are designed to fit the AR60 axleAre those normal Wraith aluminium rear lockouts and normal C-hubs and normal knuckles ??
no, you could use the plastic lock outs...Or do you need different rear lockouts and C-hubs and knuckles that are bigger on the inside cause of the Boom Racing tubes ??
I would believe yours should fit just fine. *Cause I have STRC aluminum rear lockouts and aluminum C-hubs and aluminum knuckles
On both of My Wraiths and are curious how they install and if I would need different ones ??
These are AR60's... not the XR10 axles (not the same width)They don't look like they have the flange like Beef Tubes have and you got to use the ring spacer
like the XR10 axles that have been tubed
yes they stiffen/strengthen the axle tubes.Let me ask you this
Do the tubes keep the axles shafts from bending
Cause I think mine are bent now or its the wheels not balanced
I have seen people out where I go crawl some times
Jumping there Wraiths and bending the axles pretty easy
kool thing DHey Taco
I got something for you for
I found 2 sets of these Hot Racing diff covers, that I'm not using them and where in my parts pile
For the Wraith axles and will give you a set
Cause I bought 2 sets of the thick aluminum Poison Spider diff covers for Wraith
and don't need the HR ones
--- DMG AR60 skid plates ---
I like them a bunch...
well... 'cept maybe the bottom side button screw(s).
Not sure why that screw isn't counter sunk (!?)
But will likely do that when I find opportunity.
Very stout (steel) construction... simple two minute install !
notice the front and rear DMG skids do not share the same design
"thumbsup"Taco
The black ones are yours
Pm me I need your address so I mail the dif covers
swell on the heads up for that tapered/flat head screw...Taco,
I countersunk my DMG plates and used these Team Associated 2x0.4x6mm Flat Head Screw ( [ASC4674] | Parts - AMain Performance Hobbies - AMain Performance Hobbies
Almost wore the plate out and could still get at the screw.
6mm is not too long ?
kool... thanks for the clarificationYes. My apologies for bad advice and not giving full detail. I knocked them down to 4mm so it wouldn't hit the Ring. 4mm just barely crests the inside of the case. I tried a few different screws (2-56,4-40, 2.5mm, 2mm Non Associated) and all the heads were to big. I wanted a shallow as possible counter sink and the Associated ones had the smallest.
You knew where I lived before...Now I now where you live !!
And some day I may come a calling !!
You have been warned !!
And we will do some Crawling !!
I will go to the post office, I got stamps but want to make sure its the right postage
...I already know it doesOrange stands out.
