Thompson311
Is anyone selling these escs already programmed and ready to rock. I love the idea and the quiet but I do t really want to dive into all this for it.
Hmm, I don't see any mention of improvements to the transition between sine and normal mode. That's where I'd like to see improvementNew update for the AM32 software ... https://github.com/AlkaMotors/AM32-MultiRotor-ESC-firmware/releases/tag/v1.80
Sent from my Pixel 4a using Tapatalk
https://github.com/blitz2190/AM32-Crawler-firmware
Its a fork I work on, I made quite a few changes specifically for the switch over, this firmware is not compatible with the AM32 config tool it must be used with the one included in the releases, if not you will damage your esc. Big shout out to alka for without his work this would not exist, be sure to thank him. use with caution it works for me but no guarantee.
Well...time will tell:mrgreen:And a very good fork it is too![]()
I've been using it on one of my crawlers and it does a much better job of switching between sine and normal mode IMO. Tested it this morning and just editing some video now, will post a link once it's onlineWell...time will tell:mrgreen:
Nice, I just browse through the github and download the latest fw for my iflight 55 and config tool. I see that the config tool is totally different to the one provided by Alka, I've just flashed the fw, but haven't tried it yet since this is a spare esc that need to be installed to one of my rig to be tested. If I understand correctly there is a throttle curve settings in the config, can you please elaborate more on this fw.
I need to write a wiki, so there are a few things you will want to do, the throttle calibration is similar to most esc's, power up the esc with the truck off the ground for safety, then while holding the throttle full power on the remote, you should here 2 beeps, move the throttle back and forth to its full extents a few times, then leave it centered, the truck will beep 2 more times when it saves the new values. for throttle curve the numbers in the grid represent what throttle percent the truck will see at the set number. P1-P10 represent throttle input 10% - 100%, and the numbers in the cells are what they will map to in the esc, so if you set P1 to 5 when your throttle in the remote is at 10% the truck will see 5%, current settings are what the midpoint will be set to when in sine mode, this firmware varies current, at the lowest speed sine mode will use 70% of this value and at full sine speed(not full speed just the open loop slow crawl) it will use 120%, the reason for this is at slower speeds it needs less current to prevent the motor slipping and higher it needs more. this also helps with heat.
Let me get this straight, when first starting the esc, do I hold the throttle full power while turning it on, or as what I understand from your comment above to turn it on then hold the throttle full power.
1) power on esc
2) while holding throttle full, power on remote, should here 2 beeps
3) rock trigger back and forth
4) leave trigger centered, after it beeps 2 times again its saved
Do you know what version you used? V1.3 has been pulled because of excessive heat so if you've got that one might be worth swapping to 1.10 which is the current latest version I thinkOkay, have time to try the "crawler" version of AM32 last weekend on my iflight 55A. Follow installation and calibration instructions (using the specific config tool for this fw). The esc got hot pretty fast during the sinewave run, much hotter even than standard AM32, going back to the 1.74 Dixie Low Heat version made by voodbrew to check whether it's the hardware issue, and it's run much cooler. I understand iflight 55A is very prone to heat build up due to its design (I read it somewhere), but I still going to follow the development of crawler AM32 fw, perhaps there will be improvement in the future or it might be my mistake on the process of installing and setting it up. Learning from my previous experience upgrading Holmes Crawlmaster Mini firmware from v1.1 to v1.2 the esc settings might changed during the process (which in my case made the esc unable to arm), and I found it after comparing the settings on my esc after flash to the one in Holmes video. This might be similar case.
