my esc is hglrc 60a but not work..try 1.74 wraith 1460kv work on slow throtle...and hard cogging and not spinning on midle and high input...
Try another firmware, on my esc wraith32 not working well is too
I try all firmware on my hglrc t-rex 60A and not work...i try 1.74 hglrc on my hglrc to and still not work....Try another firmware, on my esc wraith32 not working well is too
mybe hglrc dont support am32 crawler
Did you use this target ---->
#ifdef HGLRC
#define FIRMWARE_NAME "HGLRC_60A "
#define DEAD_TIME 45
#define USE_TIMER_15_CHANNEL_1
#define INPUT_PIN LL_GPIO_PIN_2
#define INPUT_PIN_PORT GPIOA
#define IC_TIMER_CHANNEL LL_TIM_CHANNEL_CH1
#define IC_TIMER_REGISTER TIM15
#define IC_TIMER_POINTER htim15
#define INPUT_DMA_CHANNEL LL_DMA_CHANNEL_5
#define DMA_HANDLE_TYPE_DEF hdma_tim15_ch1
#define IC_DMA_IRQ_NAME DMA1_Channel4_5_IRQn
#define PHASE_A_GPIO_LOW LL_GPIO_PIN_7
#define PHASE_A_GPIO_PORT_LOW GPIOA
#define PHASE_A_GPIO_HIGH LL_GPIO_PIN_8
#define PHASE_A_GPIO_PORT_HIGH GPIOA
#define PHASE_B_GPIO_LOW LL_GPIO_PIN_0
#define PHASE_B_GPIO_PORT_LOW GPIOB
#define PHASE_B_GPIO_HIGH LL_GPIO_PIN_9
#define PHASE_B_GPIO_PORT_HIGH GPIOA
#define PHASE_C_GPIO_LOW LL_GPIO_PIN_1
#define PHASE_C_GPIO_PORT_LOW GPIOB
#define PHASE_C_GPIO_HIGH LL_GPIO_PIN_10
#define PHASE_C_GPIO_PORT_HIGH GPIOA
#define PHASE_A_COMP COMP_PA0
#define PHASE_B_COMP COMP_PA4
#define PHASE_C_COMP COMP_PA5
#endif
??..maybe that helps https://am32.slack.com/files/U01HQ0Z7ZB5/F02C7GV3L9G/am32_hglrc_1.75.hex
Yes ...you must be member on slack but certainly the hex is on github too
edit: you got mail "thumbsup"
....and?? Does it work ??ok work i used Hglrc 1.77.hex flashing with arduino on esc configurator 1.7.1
step to flashing hex file on esc configurator :
1. install bootloader on stm cube programer
2.install wraith 1.69 full.bin on st cube programer
3.install eeproom on st cube programer
4. conmect esc to arduino and esc configurator then read M1
5 go to flash menu. then upload flash firmware hex file and klik flash
6.setting the motor on esc config and done
What motor do you use ?
yes it work smooth...i'm using DYS D3530 1700Kv
I know Óscar vh has successfully flashed this ESC with AM32 since he posted a YouTube video of it in action. Unfortunately, my Spanish isn't great, so I don't know the details on exactly how he did it.
That is true but he used the flycolor xcross 50A... not the francy ;-)
On the Francy the BEC board is above the two flash contacts ....so you have to remove that or you get a different ESC.
"thumbsup"
First step....sign in on the AM32 group on slack https://am32-invite.herokuapp.com/ ...there is a recent post about somebody who wants to do exact thing to the smaller brother ESC(30A). You can find all targets over there too and the developer frequently answers questions !Ahhh, I didn't catch that detail. I guess I'll take a look at how easily the BEC module will desolder from the main PCB. If I only have to remove it once to flash it and solder it back I still consider it a win to keep the package small and uncluttered.
The image below has a sideview. Looks like they used a big solder blob on each of the main battery terminals and smaller ones on the opposite corners. There are metal fingers around the edge, which I imagine are ground plane connections, but hopefully those aren't soldered.
Do you know which bootloader Óscar used for the Xcross?
https://imgmgr.banggood.com/images/...4/F7/000c329f-fcf6-4886-8836-d864c5ffae1c.jpg
See you there "thumbsup"
Thx man, kind of what I was thinking, I guess I'll pull the trigger and buy a couple.Yea. Older outrunners, are just as good imo. The esc doesn't care. There are no circuits in there. Just wire.
Sent from my SM-N986U using Tapatalk
Price and quality of magnets and wre size matter some. But an old revolver will still kick some assThx man, kind of what I was thinking, I guess I'll pull the trigger and buy a couple.
