TomFrajer
Body post holes are drilled...
Been thinking about a dual shock setup but my only concern is the ahocks arent parallel with many aftermarket trailing arms. This doesnt create any binding? Seems like the shocks may be better aligned at ride height. This is the only thing holding me back...
using BEC ? i actually took mine out and put a spektrum servo glitch buster in place of it and solved my problem, but... ended up it was just a bad bec and havent really found a need to re install one again.Now I have problem![]()
Steering is lagging. It is either faulty servo or receiver... will have to investigate this...
to keep Rx absolutely waterproof put the Rx inside of a large baloon or best solution is in a condom and tie it off or rubber band the end around your wires, we use em in nitro boat racers all the time and works perfectly, lil hard to explain to folks that you need to use one on your ... rig. :lmao:Just checked steering again before breaking into receiver box --- and it works! :shock:
I hope it will keep functioning :lmao:
Yet ANOTHER killer tool i have to add to the box, Thanks Tom.
