binaryterror
Well after over 2 years with the old Delrin BeetleJuice V4 I wanted to move to lighter weight (looking for the 4.5-5lb mark not super light) and having seen and being able to purchase the new T1E Sniper chassis from Nick/BTF at Battle Grounds this past weekend I had found the new direction for Nationals and beyond.
As it sits now:
I've been compiling a random selection of parts for the rebuild plans and parts for the rebuild:
T1E Sniper CF Chassis
T1E CF Wheels
Switching FX-R's to Sidewinder Micros (just to try this fad out)
Switching 8711 to 8711HV (might as well swap the spare in while its all apart)
Kyosho 3.7" Velvet Shocks - SuperShafty.com rod cap mod - w/ custom lathe work
CKRC Rear Axle Tubes & DLux 7075 Aluminum Shafts (SO BEEFY)
klabeaume Custom lathed front tubes
SDS Super 300's...original set since release old but just scored rebuilds to revive them
CKRC/Berg 3rd Gears
Gunnar pins in berg gears and front axle hexes
DLux Servo mount and no-slop king pin bushings
DLux Knuckle Weights
Rowdy Racing Elec/Batt mount (no clue what ends up on it yet)
Krawler Konceptz Skins
Axial C-hubs
VP Berg Knuckles - 12mm bearing mod (JeepinDoug)
LHS Bearings
Fastener Express Aluminum, RC4WD Titanium and Black Oxide hardware throughout
Titanium lower and Aluminum upper links
Br00d Apocalypse Type S-HHK 35 Turn Motors
Shaved/ground cases - milled motor plate
Frsky 4PK compatible RX - decased
Some pics of the above parts:
As it sits now:
T1E CF Wheels
CKRC/Berg 3rd Gears
Axial C-hubs
LHS Bearings
