Snow Wheeling
Its that time of year snow has fallen in Colorado but we will have some low to mid 40s days that are perfect for crawling. My usual favorite place to crawl has a fun Canyon that is hard enough for most scale trucks in good weather let alone the snow.
I grabbed my JK8 since I figured the Portals, large 4.75, 3800kv and winch would all work to my advantage in the snow. It is a heavier truck at 8lbs but it seemed to work well.
Poser Rock
We had about 2-3'' of snow which is the perfect amount for snow trails in my opinion, it was also very dry snow so there was a surprising amount of traction available if you knew were to look.
I don't think there was a single tire combo that could have made this climb. Its my typically wet tire test rock since its a smooth granite that you have to pass through a creek to get to the base of, and my Alien RB weren't able to grab more than half way up, the the G8 Trepadors on my Buddies Gatekeeper were about the same. I winched to the top and then Pulled the GateKeeper Up.
Vanquish on Ice!
Typically there is anywhere from 1'-3' of water here. Now its a few inches of Ice.
Another Section that is hard enough in the dry, this time the loose dirt was replaced by icy dirt and snow, we both had to winch over the rock to the right that pushed you up against the bank on the left side which has become undercut from erosion and want to flip you backward.
Once out of the Canyon you make it up into the sun, where you are back in dry loose dirt and much grippier granite.
I also got to take out a newly finished 2.2 truggy I have been working on for a while.
But that's for another thread if I ever make one.
