What powers your SCX10?
Re: Please list your SCX10 Motor, Battery, and ESC here!
Which battery type/ number of cells and with what motor, ESC and gearing? I guess if you are using larger than stock tires or anything else that would affect the end result, that would be good to know as well.
example- 2S Li-Po, Tekin FXR, Integy 35T lathe motor, stock gearing
You can keep checking back to this original post for updates as we gather the info. Thanks!
EDIT: As of Post #111
Batteries Listed:
2S Li-ion............. 1
6S Li-Po.............. 1
4S Li-Po...............1
3S Li-Po.............35
2S Li-Po.............32
Unspecified Li-Po...2
6 Cell Nicad.......... 1
8 Cell Ni-MH..........2
7 Cell Ni-MH..........4
6 Cell Ni-MH.........17
ESCs Listed:
Axial............................ 1
Castle Sidewinder..........12
Castle Mamba Max..........7
Castle Mamba Max Pro.....2
Dynamite Tazer.............. 1
EZ Run 60 amp BL........... 1
Holmes TorqueMaster......4
LRP Crawler...................1
LRP Micro......................1
LRP Quantum Runner.......2
MRC............................ 1
Novak Goat Crawler.........6
Novak Havoc pro............ 1
Novak Rooster Crawler.....12
RC4WD Mayhem..............2
Robbe Rookie Truck......... 1
Tamiya TEU-101BK......... 1
Tekin FXR.....................20
Traxxas VXL-3................2
Traxxas XL-5.................14
Turnigy BL 35A...............1
YeahRacing 35A BL......... 1
Motors Listed:
Axial 27T.............................. 7
Axial 55T.............................. 4
BL Outrunner 3500Kv.............. 1
Checkpoint 9T....................... 1
CKRC Twister 35T................... 1
EZ Run BL.............................. 1
Fantom 35T Hand Wound..........1
Holmes 30T........................... 2
Holmes 35T........................... 3
Holmes Cobalt Puller 7T........... 3
Holmes Cobalt puller 10T.......... 1
Holmes CM 3014 850Kv BL........ 1
HPI Saturn 35T...................... 1
Hyperion 3100Kv Sensored BL....1
Integy (various series) 35T......10
Integy (various series) 40T...... 1
Integy (various series) 45T...... 5
Integy (various series) 55T ..... 2
JP Warrior Hand Wound............ 1
LRP 21.5T Crawler...................1
LRP Truckpuller2..................... 1
Novak 45T.............................1
Novak 55T ............................4
Novak Ballistic BL................... 2
Novak Goat BL .......................5
RC4WD 45T........................... 1
Reedy 55T............................ 1
Reedy MVP 27T ..................... 1
Reedy Spec 19T..................... 1
Tamiya Silvercan.................... 2
Tekin 35T (Machine Wound)..... 4
Tekin 35T Pro Handwound........ 10
Tekin 45T Pro Handwound........ 1
Traxxas 12T 550..................... 4
Traxxas 21T 550..................... 1
Turnigy 480S BL 3200Kv .......... 1
Unspecified make 35T.............. 1
Unspecified make 55T.............. 4
Unspecified 1800Kv 3661 BL...... 1
Velineon 3500Kv BL.................. 1
Venom Fireball 55T.................. 1
OK guys, in my scx10 i run a 55t and a 2s 4000mah lipo. plenty of power and a stump puller.
So far this week:
2s and 3s lipos, 32p gears, spur is 54T
6 turn, 950kv aircraft brushless outrunner with cheap ESC 19T pinion(coggy, crappy)
Stock 27t brushed on Tekin FXR, 13 and 19T pinion (good, but hate that fan noise)
27t Mabuchi Silver can on FXR 13T pinion (good, but motor was previously cooked from a career in racing)
Low Bucks Racing 55T on FXR 13T and 19T pinion (SLOW, incredible battery life)
20T Mabuchi from a Swiffer Sweep n Vac on FXR 11T pinion (FAST, smells like it's going to catch fire just because)
Add this to the list with a "highly recommend tag":
Esc:
Mamba max pro
Motor:
Leopard 2900 kv 4 pole sensored 3658 (max motor temps after 1 hour of running are 25 degrees above ambient, or 115 here in texas)
Battery:
3s of various capacities; 4000 mah to 5000 mah, turnigy and other no names.
Gearing:
16/87 (I am running 2.2 Swampers)
Smiles:
Limitless
scx10 running a HH BR-XL, Tekin 30T HW, Castle Bec. Usually running it on 11.1 volts. But for trailing 7.4
