What powers your SCX10?
Mine runs crap it shouldn't be
Traxxas waterproof servo (doesn't mount on right)
Xl5 esc
Rc4wd 45t motor ( dose of work with traxxas motor wires)
Futaba t3pl radio and receiver
Zippy rc 6500 2s lipo
Re: Please list your SCX10 Motor, Battery, and ESC here!
Currently running a HH Crawlmaster 1000kv bl outrunner with castle sidewinder 2 esc. On 3s with 15/86 gearing. In a couple weeks I'm switching to a tekin 30t hand wound
Castle sidewinder 2 esc. Spectrum rx/tx Holmes torque master 540 35t 3s lipo 15/87 gearing
Speed Passion Reventon R w/ crawler firmware and a speed passion 17.5mmm sensored motor. Crawls nice and slow but has decent wheelspin when needed. Works great as long as I keep it dry haha.
Tekin RS paired with their 17.5 sensored motor on 3S. Smooth low speed crawlability with enough top end speed to keep me happy.
Tekin Pro4 4000kv on 2s, backed with a clapped out MMP with a BEC and a savox servo controlled by a Airtronics MX-V. She pulls wheelies and I've haven't ran it with 3s the motors not rated for it so I don't both but some say it can handle the voltage so I might try it one day. Gearing is 56/13
Finish building my rubicon kit last weekend. running Novak Eiger Pro combo (ESC, BEC, Rockstar 35T brushed) on 3s, geared 14 / 87. I run trails and try to keep my driving looking scale. So far very happy. Runs cool and torquey with enough wheel speed when needed. Steering is handled by my trusty HS-5955tg.
looking to run a Holmes Hobbies torqemaster pro 540 27t motor with a castle sv3 esc on 2s would that be a good setup for class 2 comps? any gearing ideas?
Venom power 4600 nimh 6 cell axial 20T ae5 esc axial nvs light controller
once u go hard you never go home
I ordered my C/R Edition last night. I also ordered a 45T motor and a 2S 7600mAh Lipo for it.
What gearing would you guys recommend?
Current setup scx10 27Tmotor 20 tooth pinion 56 tooth spur. Venom 2S 5000mah 30C lipo. Thinkn oof going to a 17 or 18 tooth pinion
once u go hard you never go home- MASTERMOUSE RC FABRICATIONS
five got a pretty much stock SCX10 Jeep wrangler still running the 27T motor. I'm looking to upgrade to a HH Torquemaster pro 35T. i already plan to upgrade to MIP drive shafts but I'm wondering if i need to change any of the gear(transmission or axles) which i change to the new motor? and if so what should i change to. below is what the manual shows it came with.
Stock:
Pinion 48DP 20T AX30578
Spur 48DP 87T AX30672
20T Drive Gear AX30394
Bevel Gear Set (38/13) AX30392
Thanks in advance for any suggestions.
