What powers your SCX10?
Im Still one of the stockers here:
AE-2 ESC
Stock gearing
Axial 27T
Various NIMH 3000-4600ma
Will be getting my first lipo in the next few days. Still eyeing out a new esc so i plan to run 3s lipo and a 35T motor
I also got the Novak Goat 3s with the 21.5 ballistic motor. 15 tooth Robinson pinion gear and a 93 tooth Robinson spur gear. Robinson hardened steel tranny gears, Hitec 7955TG servo, MIP driveshafts, and a couple different 2s and 3s batteries. All this power meets the ground on a set of 1.9 pitbulls on some proline rims.
venom 240 waterproof esc with the venom fireball 55t motor running on 4000 mah 2s lipos and a couple of 8.4v nimh batterys gearing is stock 87 tooth spur and 22 tooth pinion!
Old school 1st gen Tekin Rebel with 12t 550 out of Losi Strike. My other setup is an EZRUN SC10 with Tacon 1100kv 3650. Both setups powered with 2s LiPo.
Update: was powered with used Novak Rooster Crawler with 45t RC4WD brushed and now powered with Mamba Max Pro. A sensored 13.5 or 17.5 is next on the list and my super scale Hummer H2 body and 9Turbo light and sound will be here very soon. I'm starting to remember why I was on break from this hobby for the last 13 years $$$.
Velineon and vxl-3 9t pinion 87t spur running 2.2 tires. Only use 2s cause it never ever breaks and still does wheelies. This velineon stuff works great and its affordable. Wish I had an elocker!!
hpi 105906 sc-15wp waterproof esc W/drag brake
Axial 27T motor
stock gearing
1.9 Flat Iron Tyres
1.9 Ripsaw Tyres
:roll:
.8)
Turnigy 2200mAh 3s 25c Li-Po.
Mtroniks Plasma45 6.5t (4400kv/rpm) Motor.
Turnigy TrackStar 1/10th Scale 60amp ESC.
Ansmann Racing 14t Pinion, 32pitch.
Traxxas 54t Spur Gear, 32pitch.
Axial Over Drive 63t/14t Gears (AX30401) Front/Rear.
Sean
