Benp
Nice!!!
Prepped & ready for surgery, Doc! My baby 'Rex needs some TLC in drivetrain/trans/F.&R. Diffs/portals, she been clicking and making noise a bit lately while in motion, so deciding to do only my 2nd tear-down, clean, re-lube of the drivetrain parts, check all bearings/clean/re-lube...and HOPEFULLY fix my rat's nest wiring! Lol.![]()
R.C. means both;Remote control, and Rock Crawler.
I say, any grease, is always, ALWAYS better than NO grease! Lol i personally picked up a tube of (dont laugh) SUPER LUBE from a hardware store and have been using it across multiple RC cars, with no issues, although, if you are like me and find yourself unintentionally mud bogging the heck out of your rig, you may want to go the "Marine Grease" route, albeit, this tube i have claims its marine-worthy. I originally bought it FOR MY Trx4 Sport, and in my 7 ish months owning it have only down the teardown,clean,lube,re-build one time, roughly 2-3 months ago and have "accidentally" been headlights-deep in water a handful of time which i wasnt planning on.Man, I hear you. I have some clicking and sometimes grinding, I definitely need to re grease my gears for sure. Had my TRX4 for about 7ish months and never greased anything yet, shhh don’t tell!
Probably going to go to that now lmao.
I have a tube of ParkTool Bicycle grease, can I use it?
My only suggestion is to make sure and very carefully either pry the "seal" off both sides of EVERY BEARING you come across, clean with brake cleaner or similar, even wd-40, then blow-dry with compressed air, and check spinning resistance. I usually grip bearing between corner of my thumb and pointer finger, (grabbing ONLY the inner bearing race, making sure to not touch any other part and create drag....you can either A:feel crud in the bearing as you spin it, or, Bnce clean and DRY, spin it hard and it should "free-wheel" for several seconds with no abnormal noise, and that tells me the bearing is re-use-able.
Alternatively, if u have mad stacks in the bank you can always just replace eveey bearing, anytime you pop open the trans case, etc.
You are overdue, get'r'lubed up, son! Or your wallet may end up hurting more than a few bucks. Any lube (GREASE) should at least be ok till next rebuild
Told ya so! [emoji6]My first tear down/grease job on this rig. had a few bearings to replace but other than that it went smooth. Hopefully I don’t hear any clicking anymore! [emoji1696]
Lol i have the same work stand as you! Hahaha love it, btw.Lmao, you sure did.
The little spacer that goes on the c-hub on the front axle(picture for reference), I am missing the top and bottom one, so I’ll have to replace those also. Does it make a difference not having them? I don’t know how long they’ve been gone, but I haven’t see a difference.
I dont know what size the sleeves are, but here is redcat version for a 1/10 on road car.Lmao, you sure did.
Might even get away with TRX "shoulder screws"I dont know what size the sleeves are, but here is redcat version for a 1/10 on road car.![]()
Might even get away with TRX "shoulder screws"![]()
Great weather so got out and ran my d110 with my buddy's 324mm w/b '76 Ford. The last time that we hit the trails, he out performed my short wheelbase Bronco but not by much. His longer 324mm wheelbase got him up the steeper inclines with less wheel-spin. Subsequently he wasn't bouncing around as much and was able to plant his rig at the top where he intended... Whereas frequently I was just lucky to make it up. That left my rig more at the mercy of simply wherever it landed... usually perched more precariously lol. The weight of his rig is also a bit lower and more biased over his front axle compared to my Bronco, which helped him out-perform me. I think his Thornbirds were getting batter traction than my Bronco's Swampers too but hard to say for sure.
But this time I left the Bronco at home and grabbed my 324mm w/b Defender with cut Boggers. My d110 is a bit heavier than my Bronco although a little lighter than his Ford but this time I was able to match him obstacle for obstacle. I probably had a little more wheel-spin than he did but I made it up without falling off the intended line most of the time. The cut Boggers really grab at the ground too and although he was running Ground Hawgs this time, both rigs remained evenly matched throughout the day and it seemed like the Boggers and Ground Hawgs performed about the same.
Anyway... here's the Ford again. Hope I'm not posting too many pics of his rig in this thread but I didn't even get any of my Defender this time. I'm ready to do a late 60's or early/ mid seventies body now that I've helped him complete his. And I really like his Ford so much better than my meh Defender. There's just so many of 'em out there now.
Lmao, you sure did.
Got my 2200kv revolver to replace the puller pro, cant wait to drive it
Dont be sorry! its the best looking body ive seen in a while, although i may be bias since thats pretty much my 1:1 dream truck.
You just keep posting pictures of that Ford split grill. [emoji106] Fords best body.
Great description of the comparisons between the 2 on how the handled the terrain. I like that a lot.
I know this is like 2 years ago, but do you remember how you did/where you bought the plate? I tried printing one and it came out super fuzzy.
