What did you do to you SCX-10 today?
New stick shift.........or light switch, whichever you prefer. 8)
New Gear Head Recon G6 limited run bead lock rings from RPP Hobby.
Took it to it's first scale comp. Didn't come in last so that's good, but could have done better had i not needed to go to the pits twice
First i pulled the passenger side front shock out of the shock mount. Fixed that, then 2 gates later i pulled the panhard bar mount out of the axle. Bolted it back down but a few gates later, it was out again.
I've gotta doublecheck my endpoints
Heavy duty zip ties let me finish the course, but with penalties i was 30 minutes from the leader.
but other than that, it performed flawlessly! Waiting on steelerzman to upload his pics as well as motorman's gopro video
Received my Vanquish stage 1 kit and loving it!!!img.tapatalk.com/d/14/06/03/a9e5a4ev.jpg[/IMG]
Well I was able to beat on my rubicon this weekend for the first time since I did the cms metal links and batter relocation. Built some scale accessories for it yesterday. And bought a airboat to put on a trailer behind it.
Purchased a Wraith kit and finished it out in VP parts and other upgrades. 3 of my close friends have SCX-10 so I decided to make the purchase as well. Received my Axial G6 on Monday and going to begin the build soon as work slows down. Hoping to begin this weekend.
Took my G6 for a test session, before our "No Man Left Behind" competition next week. Bound it up a little and twisted a drive shaft
New Chevy for Axialfest."thumbsup"
After pulling the panhard bar off the axle and removing the plastic the screws thread into while doing it, i replaced the axle housing as well as pulled the HD OD gears from my 2.2 to go in the scx10
It's all buttoned up but havn't tested it out yet.
Added DS Pro siege ladders, RC4WD ARB snatch block, a hi-lift jack and tow rope attached with scale bungee cords.
I installed my Heyok winch controller, but lengthened the wires tot he JST plug. On the receiver end of the winch controller, I tapped into the black and red wires for power to run my lights. I was previously using the 3rd channel for power exclusively. I also installed my FS-GT3B that I just got in. I'm used to old school fm 75mhz stuff. This 2.4 ghz is so hitech! :) Now I need to test it all out, as well as my pull pal I made a few wks ago.
Finished two projects.
Aluminum rear quarter panel armor:
Steering linkage, bent around the diff housing.
(Testing out tapatalk. Hope this works. )
Sent from my SGH-T679 using Tapatalk 2
