What are you working on??
Gave the beater the robinson racing treatment!!
Nothing.. Haha It's all working fine.
I did use the trucks at Reid today with the family. Beautiful day and surprisingly hot.
dGP1Kdjg6DGR2-WaFq7SkAYgrf-ownwwL_9_I9jbJ07uSuFikso4ChKqZWx6In7Zsvsz5JBSKlgiy-oDCwqA0AqRNb0AJScrZ-sYQ-VgsdanaoMqE6YxyQgnXKKr1vK0rUj0CJs1C48P1DHeYnr1YFh_CfI5vIAE2UdfzyWwC0tslcFwzlTud1nD3im3_kyfdRVXz4ATRbhvAMsAIH-msvZC6HIEH2t1GiKoliXhmfVsHMfD7vhDOpjs-LW7tUYcCphSLPnoCURmuPQbdJPNX8pGfXOAKXEVrdMNF81ZYFLpfjSdXa-CoQNAXSQ07catsv43n46JNrPP9S8dNy-6yEnpOw4la2FXgWzjhUhUTU1YoDMYgPJRp3d8aOEBIKEczE8h0jd42JYkKdZ3YyR1xo-U6Kar__1VgpyLpCsbEQcJCb_G70v6-1w4sM6bsaV8hQQ_OO_Cdj47B7XGRy-2KZAcyHSuo33J6gX6GR4466CJh9mjKsidMEIfJQc3yf-UTcXB_SQPuxx39D9gj-vs2LjRfFtyFQ0hD2qUCsZEEPo=w1553-h874-no
4Bt3ZpaTX3gQQa0Dj1_n2_N0cTUC1fEngj9Qx9y8d8FcYT6drc5csPrsLIIigbExFG5vgYEdUHHuSneqcNEYyxMRoigdwPd_JOJ8AxoTEvomeppKxvP6pla7olRRYgyGPTkrTwNRw7YAHAL1EZr8uu9i_v3yn7RQv6zYhvw8FMlivep6e7srkU8L40RyDUrIE9b8BqDtQwh1ZH5Qv9qnRlLxM5I2oMU9cXEmlAOu0qF0NiUkrUCtxG10Zc_M9Rky70jFFYrzDO6EYIAEdxPiaVFoL6oSxUAI8i8cxKBAKmqmO4R8Z2-L6ywMlNGqgEdyeCPM41xrI4spnuydINjug59wHBJyECfqgcmmPbar0GzbGM0MNUYQpxjLtpzM6zuil1MjlF2jD4-oO-5tNciVeYbfJcYg234oaxqeDaX3EngkCOMUYYdJcrz7Sipzvu99SonHNFzW7pIw08-qu6Nw5ngwHIScsdAYwmwE7RsbX50nhWqhwYloNe-KEHBrH5-lMEuFEMIvJW3x3o4LB6Yc8IDAN6hDaSNcV599H-NOGKo=w1553-h874-no
KfuSqGqGUJGoREfxnX95vB3VGdriw8EM1hIYtdWfdzKtXu3LFMbd-dVxnN6CRdmeFGkUYIM49I0lSbqaVrVjtSrpGU8EVjkw4u3fqrv6NtXUN3IXXCR9v-vR5BthVG2hTGfdouSkhOjb9ifCprW9moeTQogU6DGdbU8QOtCnIME_0hPF8oPfGhHQDcrHaxKTMKkNXi0yhHuRit9k0RCq04eZhLaDwE84rIGzaAZycNzWOWP88VmkvF8SdKqBNMqTGaZmFsX0RxeDZu0Kj-JzdsfMiY3sh92ZTdDo96l5o1iVluqTf6TiGHW-rdd6jslHI_h_J58ZTGxhC_6xHu6XBZNAkbhKXyvPiIvEetOpcjO7KFiBcnFh4leMXhsyObZxaxbjyd0mvuPEVwsCtS-6fT1oXVJBmaflyh1rbMtvkSS9BuYB9VeHtSMk-5ttcN7Th1QxU2HaeMFvktIJGPQzPF81uURslEgmv4E973vKb7B-mbyKchqWzhtY6e1u4hQKY4HSZdlz2PX3DMH_lFNuWMokZ4DskpnDlYqQWrKzuQ8=w1553-h874-no
For some reason i can never see your pics Robert. Probably just my stone age cell phone!
Sent from my C811 4G using Tapatalk
I put overdrive and underdrive gears in the beater just to see how much better it crawled and was very impressed. Then put a cut on the iroks for better bite. Works really good but need a little stiffer foams. Can't wait to try it out at maidens!!
[/URL][/IMG]
Finally got the center front diff installed for 4 wheel front steer on the Beast II, now just waiting on the rest of the parts to make it turn!!
I have removed some of the ballast weight from the Power Wagon and I'm in the process of relocating the battery tray as well.
But what I've really been doing is painting the new King Hauler lid.
Which I did a crappy job of.....:roll:
But here it is from some angles that make it look good.
Was going to buy links for the tundra, but I think im going to try and make some from 3/16" steel rod. Should give me some good weight down low.
Ok thanks. The gcm ones are beadlock and I'm really looking for beadlock a for ease of changing tires or foams. Either way those wheels look sweet!
Ben
So, I've been dubbing with the Mistress this week.
I started with removing a 12.9oz. ballast weight from the rear, relocating the battery, ESC, and Rx for better weight distribution and center of gravity.
I used an Axial Rx box that I cut down as a base for the battery tray.
While removing the light bar from the roof I noticed that the Honcho rear cage had ripped out one of the mounting holes in the back of the cab.
So I dug out the bed and patched up the torn bed corner and reinstalled the bed in place of the cage.
Then I transferred a few of the scale items into the bed, though I think the cooler may be slightly vulnerable.....
Next up is mounting the winch without the added weight of the steel bumper.
I'll keep you posted.
Where did you get the mini liscence plate made? I need one for my blazer! Thanks
Ben
Ben, I made those myself.
It's not hard, I get them from the DMV website and shrink them to proportion.
What plate type(breast cancer, custom, antique etc.) and what do you want it to say?
Back to my progress, I found another #2 cross member and put it where the #1 cross member goes and cut the mounting posts off them.
Drilled some holes and mounted the winch.
Now I'm ready for a touch-free run on the north end of Reid SOON!!!!!
