rockspider
Hi all,
was looking for a funny title and that was all that came to mind, sorry... ;-)
Anyway, here's my Phoenix build, from Italy.
Some of you may have seen in the main Phoenix thread my custom modifications to better seal the guts of dig and OD from environment, basically the stock rubber flap was discarded and some Nitrile glove fingers were cut to size, with a tiny hole for the lever to snug fit inside.
Then the original external flange was dremeled to enlarge the opening, to give the nitrile boot more room to flex around.
Flange is then assembled inside-out for a better press-fit to the boot.
Yes I know "green" gloves does not look so cool, feel free to use a black glove if you like the mod :lmao:
Second thing I modded was servo placement. Personally I always try to keep CG nice and low, and having battery on a lifted support and big servos high mounted didn't look nice to me.
First I thought that a low profile dig servo could be installed below the stock mount. Linkage and servo arm selection had to careful, since space is at a premium at full suspension compression, but was able to keep the upper rear link to barely kiss the linkage at full stroke, without any binding.
Second I deemed the OD servo did not really need fullsize strenght, so carved a simple L mount from black pvc profile and installed a mini servo. here too linkage needed to be custom.
Last, the huge battery shelf was ditched alltogether. I will be using mainly 3s 2200 lipos (as most all my rigs) and by pure coincidence this size fits like a glove (gloves, again? :ror in the space left between tranny and dig servo, laying flat on framerails. Dig linkage runs below frame level, out of the way.
Now everything is low and flat "thumbsup"
Really happy how clean the final assembly ended up :mrgreen:
