Is there any sort of instructions so i can get an idea how it all goes together?
I got my hands on one of these units during the Axial West Coast Championships this weekend. I can't wait to get it installed. Tons of awesome features in a super compact dig unit. "thumbsup"
I have ordered a silver one...They are available yes?
With people talking about servo plates for smaller servo's, VP could just make an adapter to suit the existing one making the best of both.
I already know that Tupers:roll:.
OMG! I just installed mine in my GC2 chassis and it fits perfectly. Fit and finish is top notch. I did a little testing in the driveway tonight and it shifts like butter. Engages and disengages flawlessly every time. Now I just need to get it on a course for some real testing. BTW I'm using an airtronics 738 servo and it's probably more than I need. Great product!
Glad you're liking it"thumbsup"OMG! I just installed mine in my GC2 chassis and it fits perfectly. Fit and finish is top notch. I did a little testing in the driveway tonight and it shifts like butter. Engages and disengages flawlessly every time. Now I just need to get it on a course for some real testing. BTW I'm using an airtronics 738 servo and it's probably more than I need. Great product!
glad you're liking it"thumbsup"
Excuse the newb question - but working on my end points for my dig - I am using a 2pos 3rd channel and want to know where I should but my end points too... Seems as if I set the servo to throw the lever all the way forward, and the dogs are not engaged, it takes quite a bit force until the lock into position... should it be fairly easy to turn the drive line by hand to lock in the dogs or should it be really tough to turn them by hand and once locked in, set the end point there? I have it set currently so it is easy enough to turn by hand and lock in... And the same for setting the rwd locked position.... Just don't want to damage the internals or the servo... Let me know if more information is needed.... I am using a JR Z590 servo for my dig...
Thanks!
SS
you might be wanting an answer from VP, but I'll try to help.
I have the shifter set so it touches(barely) the dig housing when in 4wd, and rear lock. and obviously floating in the middle when rear freewheel(this doesn't apply to you with a 2 pos 3rd channel)
mine clicks loudly into 4wd and rear lock-takes some force(maybe a 1/4 revolution of tires?)by hand, but when actually driving doesn't seem bad at all. It'll bind for a second til cogs line up(I think).
make sure you're linkage is long enough. or re-center your servo horn if not getting enough "throw".
the internals, as long as your shifter is as far forward(for 4wd) and back(rear lock) as it can go, you will not be messing up the internals.
think I read your post right, if not, hopefully it can help somebody.
OK that helps actually... Going forward I can see that the motor will drive it enough to lock the dogs up properly allowing the lever to move the rest of the way forward.
And I would think, that you wouldn't want the back overly tight before the dogs line up because dragging the rear tires may not move it enough to lock up.
I have plenty of room to adjust that is for sure. Just want my end points set so the servo isn't in a constant working state and that the dogs will still engage properly. Being my first dig, I am a little gun shy on that part I guess.
Hopefully VP can chime in with what they think is the best setup as well.
Thanks again!
SS
sounds like you got the idea, i dont think you can hurt the dig at all, spin the tires and slam in and out of gear. "thumbsup"
