Vanquish Products Hurtz Shifter Dig
received my VP Dig 3 days ago and i have used the hell out of it and havn't had a problem yet!!"thumbsup" although it does take a little grinding on an aluminum tranny housing to get it to fit8) other than that I LOVE THE VP DIG
Tom, i sent this to you in an email the other day but havent gotten a response:
I am needing the little dowel that is located on the bottom of you ax10 dig housing that the shifter arm pivots on. Somehow it fell out while crawling one day and I never could find it. Tried running a bolt through the housing to hold the arm, but that didnt work very well. Let me know what I need to do to get one of those pins. I ordered through RPP Hobby if it matters.
Please let me know how I can get one of those dowels/pins from ya! Thanks!
Pm me your address.
Jim
The VP dig. Best fitting RC product I've ever purchased. ive ran my 2.2 for 2 years with no dig and dun veary well...but thanx to VP its on in 2010"thumbsup" thankyou GSRCC Drail
just got one from rpp......its on the way. i had no clue it will not work with a cobalt motor so i am now freaking out. I REALLY dont / cannot spend 80 on another servo. is the micro mount out or anyone have advice?
Hey question, i have a SWX with goat motor will that fit, i hade a problem with dna the servo mount did not fit , will this servo mount give me the space to mount the servo with that motor?
x3
I'd like to know on a micro or mini mount to work with my Cobalt puller. Or maybe i'm confused and there already is something that will work??
Also, any further info on the dual dig?
Is it possible just to purchase a new shiter arm. My dig started giving me issues so I took it apart and found that the boss on the inside of the arm was mushroomed and would not lock the drive in place. I can take a photo if you need it. Otherwise this dig unit is great.
Thanks,
Bernie
Thanks,
Bernie
Send me a pm with your address.
Are your endpoints set properly? you do not want the servo to be pushing to a hard stop. It should just be holdig the shifting portion right before it hit hard resistance.
any ETA on a micro mount?
I would like to know what servos people are using, so I can get a mount done. For mini mounts we have a losi mrc here with a small servo, I assume this is the size people are using. But I see some with 4 screw mounts and some with 2 screws. So I could use what servos people are using to go find technical data on them see if I can make a mount to accomodate most of these servos.
Jim
Jim
I'd like to utilize the Hi Tec 5245MG mini that I run in my current dig set up "thumbsup"
I'd personaly prefer a bracket with 4 screw mounts...nice and solid.
http://www.hitecrcd.com/servos/show?name=HS-5245MG
reversing the dig?
Is it possible to run this unit in reverse (opposite side of the trans) so that way i could have the front wheels free wheel and the rear have power or 2wd? I always wanted a truck i could shift from 2wd to 4wd. If it does work in reverse i guess you could do "burn outs" also. "thumbsup"
Sure, just switch your axles and motor wires around.
hey yall i got my dig in october and have been really happy with it until tonight. i stripped the idler gear in my trans today and had to do a teardown, as i was in the process i saw that the output shaft in the DIG was very wobbly(bushing worn badly), and the shiftfork has the same problems as the guys in the previous post. im using the blue (star) synthetic grease that VP sells and have been since day one. how would i go about gettin replacement parts:???: and how much?
All individual parts are available to be purchased from the website now.
Jim
i run a hitec 225mg......i had to make a small adapter on the bracket to clear the puller motor........i would like the micro mount but i assume it will hit a puller can too?
