We finally released our patent pending foam system for rc rock crawling trucks. "thumbsup"
One foam system includes everything shown, More than enough materials to setup 2 tires in any combinations you can think of.
Want stiffer sidewalls? change out inserts, from ,soft,medium, to hard. Or cut them up and add in different variations into the same socket for different performance aspects.
Also with the different layers, you can easily changes how your tire deforms over rocks, You can make the center stiffer, or the center softer. By switching out the layers.
To cold for memory foams? Take out the memory foam layers, and add in the black foam layers.
With this system, there is no more buy it, and hope it works for you. You buy it, and change it up till it fits your drive style.
Atm we have 2 different diamters to chose from. 5.125 dia and 5.5 dia.
