shakemandril
Will this chassis work with the Toyzuki front motor mount? It doesn't appear to be a "C" channel style chassis in the pictures but I can't tell for sure.
correct. the raised upper links will require shorter upper links to acheieve the same pinion angle. the stock holes for upper links are also provided if you would like to use your stock(or blue monkey) upper links. however you wont be taking advantage of the improved suspension geometry of the SCXHR chassis.
As far as the correct upper length im unsure as I custom make all my links for there specific application.
One way to get a close measurement would be to bolt your upper links to the axles. then hold the loose chassis ends over the mounts/holes with the pinion/axle angle you desire. mark the links at those spots then measure the length or difference they need to be shorter.
good luck, you will love the chassis!
So I got this chassis yesterday and the skid seems a bit wide. I see you used the stock bracing but with the skid assembled the stock bracing is about 1/4 off. I'm using your smoothe skid also. I may be missing something but just checking
yep just like stock the skid is wider than the braces. simply bolt together and the front and rear of the chassis will arch inwards like they were designed.So I got this chassis yesterday and the skid seems a bit wide. I see you used the stock bracing but with the skid assembled the stock bracing is about 1/4 off. I'm using your smoothe skid also. I may be missing something but just checking
yep, perfectly, exactly what it was designed for."thumbsup"So do the stock bracing work on this?
Could I get a good length measurement of one of these chassis? I'm trying to draw up a F-TOY cage/frame to put on top of this!
its identical to a stock SCX chassis"thumbsup"
