~TSS~ SCXHR Chassis! The next evolution of SCX10 Performance Chassis
Does anyone know proper length for front upper links. I need eye to eye if you did. Thanks in advanced. It's for scx10 JK
Been running a TSS chassis on my 2.2 rig for a while now and have to say that I am very pleased with the performance and clearances over the stock chassis. I did remove the rear shock towers and replaced them with plastic Axial ones. The camera on my phone isn't the greatest, sorry for the lack of clarity, but here's some pics.............................
I put a bit of a bevel on the lower edge to aid in not getting hung up on obstacles like a sharp edge would.
What wheel base do you want to achieve?
on my 12,3" I have used the following (with stock mounting holes on the frame)
FRONT:
Lower: 122 mm
Upper: 109 mm
REAR:
Lower: 131 mm
Upper: 125 mm
and I got right to 313 mm wheelbase with nice pinion angles
I used High clearance Blue Monkey links kit
hope it helps
PS: just ordered now new upper links in order to use the additional mounting holes and change the anti-squad geometry..
sorry for the Off Topic, I saw this picture and was wondering where I can find those body mounting shown into the picture...
Your feedback would be very helpful ...
Thanks a lot!
Thanks for the order!
you can use any links you want depending on the wheelbase you wish to acheive. upper links may need to be adjusted to get proper pinion angle. ive never tried wraith links but they may not work, or they might, never tried them.
New!
Version 4! SCX10 II Compatible!
TSS SCXHR Chassis
The Scale Shop is very proud to release our all new SCX High Clearance chassis. This chassis fixes all the issues with the aging SCX10 chassis. Version 4 now fits BOTH the SCX10 AND the SCX10 II !
SCX10 dimensions and all factory mount points precisely replicated
Uses your existing skid, braces, and hardware
Front and rear "arches" raised 1/2"
More suspension up travel and full compression at any ride height
More clearance for CMS and panhard rods
Eliminates axles and upper links hitting chassis rails
Integrated shock towers
Dual raised upper link mounts, one positive and one negative anti-squat setup
More shock mounting options
Dual Bumper mounting positions, stock and raised 1/2"
Twice the torsional rigidity of stock frame
Comes in raw 12 gauge steel or 8 gauge aluminum ready for paint or welding
Combine with our TSS Smooth Skid for the Ultimate Performance Package! (OG SCX10 only)
Made in the USA
Version 4 now adds:
SCX10 II Compatibility
Laser Cut
SCX10 II Transmission mount holes
Adjustable Height Skid mount holes
More shock mount holes including both SCX10 1 & 2 stock locations
This picture really explains it all(Old V2 shown)
Combine with our TSS Smooth Skid for the Ultimate Performance Chassis for your SCX10 or Custom Build. (OG SCX10 only)
TSS SCXHR Chassis Rails
Price Drop! Now Only $49 + Shipping
Available Here:
Chassis -
