transmission issues
Mine sounded very similar when I was setting up my dig. after I had the center and EP's set right, it still made this sound on front dig only and soon it went away. I regreased everything on my truck before I ran it for the first time.
I have the same issue with mine, sounds identical, turns out it was the front center CVD, sucker would bind at a certain angle and make the noise, remove one driveshaft at a time and then try running the motor, I did this to pinpoint which one was bad. It was indeed the front center driveline. So I put the rear in the front and an axial center in the rear.
I have the same issue with mine, sounds identical, turns out it was the front center CVD, sucker would bind at a certain angle and make the noise, remove one driveshaft at a time and then try running the motor, I did this to pinpoint which one was bad. It was indeed the front center driveline. So I put the rear in the front and an axle center in the rear.
all good info guys. thanks. i am going to do more tomorrow after i fix a weld that broke on the esc wire. thanks so much for the info.
