War Pig
hey Tim
so, I have Safety Silv 45 Brazing Kit with flux now, does it work great with Stainless Steel Tubing that u used??
Yes, I think the safety silv works better with stainless than regular brake line.
hey Tim
Alright....I am gonna try it and order some stainless steel tube from that website,
By the way, it's no problem to braze these stainless steel tube on axial chassis and some other steel tubes or sheets, right?!
I am running the Tekin Rx8 speed control, I just fill them full of dielectric grease. Yeah tiny, and half a pound lighter than the T8.They both still look pretty good. That little Pro4 looks so tiny in there....Are you running the Mamba Max Pro? How did you waterproof everything?
So after frying the pinion bearing in less than two minutes of running I found some 7x14x5mm bearings that will sit nice and close to the pinion gear. all three bearings will fit in the case now so i have to believe that this will fix this issue. You can see the brass ring that was needed to fit into the 3 racing axle case to make it all work. Awesome...
Are you running 3s with the new motor?
Back together, I was noticing the huge dent in the front axle housing. Im wondering how much thats getting into the ring gear? Cant feel it dragging. Oh yeah 3s, i dont have any 2 s batts to even try it. it is the only pro4 that tekin says is good for 3s.
