This thread is for detailed pics and tech info on modifications to the RCWD Trail Finder 2. Please keep BSing to a minimum
Tips and tricks thread stickied at the top. I have bench seat in mine and a regular size servo but if you want a dropped floor you'll need to do a micro servo set up or relocate the shift servo with custom linkage .
move the front shock hoop back one hole and put the shocks behind the axle that takes care of any steering issues
I just found out, that the electronics box has the same hole pattern as the Axial box...they can be swapped with no modifications...
nice touch
Just putting my rig together last night and did this mod since I'm running xvd's, I used the 2mm spacer on the back side then mounted the shock like the leaflet said to do but I find that the shock binds once you put it at the angle to attach it at the upper shock hoop(like the max angle the ball will allow). Are you running 1x 2mm spacer at the rear side of the axle or more to get rid of the binding. Hope this makes sense?? Thanks KurtFront shock hoop can be mounted behind the front axle like this:
Your right, the shock does bind if you use the spacer provided in the kit. I used a traxxas ball end (aprox. 1/4") as a spacer and it worked out perfectly. The shock doesnt bind at all.
