i rather doubt that....that would be it "thumbsup" a 80A is coming my way as we speak.Can the flycolor esc be flashed with the AM32 using the Arduino?
Lou
Lou
Could you tell me a 6s capable esc that I can “easily” flash AM32 using the Arduino?
That's awesome, I have been looking for one with a built in bec!
Here is what he got Flycolor Francy BLHeli_32 20A/30A/40A/50A 3-6S Dshot ESC w/ LED only 20A and 40A are in stock ATM
Óscar vh is not running the AM32 firmware in the video so his slow crawl is not as good. As you can see it is still pretty good and slow though.
Drag brake is not as good as a brushed motor IMO. To gain a powered drag bake that will hold better will cause the motor to buzz like a servo in the examples I have seen, and has not been implemented on these esc's that I have seen.
Pair this with a direct power Holmes Hobbies servo and you are good to go with out all the hassle of programming AM32.
would it be possible to use AM32 in this esc? How do you see it friend?
Thats a pic from ali ...the other side is covered with a headsink so no picture. Its very difficult to say .I think it is pb4 bootloader, so start with that and just try different targets till it works, I can't tell which pads are swd or swc. so you need to trace them with an continuity tester / multimeter.
Thank you very much friend as soon as I can, I try it and comment on the result. very grateful a greeting Oscar
I added instructions on how to adjust the settings yourself using an Arduino.
This also lets you update the firmware (not with installing the bootloader) using the receiver plug instead of having to use the ST-Link.
I ordered 3 35A Wraith32 - 32bit BLHELI ESC"s a 2 pack of st links, then realized Arduino is simpler so I ordered the 3 pack. Thanks for the link! So I'm kind of not super impressed with my Holmes Crawlmaster mini v1 and that led me here.
Has anyone dabbled into one yet?
EDIT ::Just found it@Voodoobrew,
It seems, there is a new version of AM32. 1.74.
@Voodoobrew,
It seems, there is a new version of AM32. 1.74. Can you somehow, put the configuration that you did, for a 1800kv motor? i want to write the same config but on 1.74 version![]()
